#32 (permalink) | |
Country: Join Date: Jan 2008
The Detail Shoppe - Wet Glaze 2.0 - Home
#33 (permalink) | |
Country: Join Date: Jan 2011
1. dawn wash 2. clay bar 3. dawn wash or isoprop wipe down 4. polishing with griots garage 1-3 polish (meguiars ultimate rubbing compound if others not abrasive enough; no oxidation the paint currently is shiny/glossy but with many swirls and water etching) 5. griots garage paint glaze (was thinkinf of meguiars #7 mirror glaze) 6. DG (bonding agent + TPP) 7. meguiar ult liquid wax or gold glass paste wax OR some other carnuba wax 8. quick detailer (+ for future maintenance) **9. from now on wash with an inline water filter on the hose, water is terribly hard in phoenix az.. leaves white patches everywhere on the car if allowed to dry on its own. 10. chip repair before all this of course... See my issue is I believe my clear is suffering from etching. Just this weekend, I noticed the rain water on the hood when blown away with air would leave a noticeable ring on the hood (even when hood was cold). However, the ring was not deep meaning I could not feel the edge or a crust, but also did not wipe away. I assume this is type I water spots. However, the ring's shape mathces other areas of the hood that i have taken notice of over the past 3-4 months and wonder where the hell they came from (most likely acid rain when living in central PA, type II). I hope some glaze can take care of this for the time being as I am a newbie in polishing (griots garage 2nd gen DA polisher recently acquired on amazon). .. my search continues to learn how to repair/correct these water etch marks. Thanks. |
#34 (permalink) |
Most glazes are full of oils and fillers to help disguise boo boos and add gloss. One wash or heavy rain storm and they are gone. The one I mentioned above is acrylic and differs from all others in that it can go over or under wax or sealant and doesn't remove easily. It does some filling also. That doesn't necessarily mean that it's better than the rest just different and longer lasting.
Most of the time water spots have to be machine polished to remove them. Even then it may not remove all traces depending on the depth, type, and severity. After polishing try the Griot's glaze and see if it does what you want or not.
#36 (permalink) | |
The DG TPP+PBA should prevent further etching correct? |
#37 (permalink) | |
Your paint looks exceptional so the difference may be subtle after the Wet Glaze but it will improve it.
#38 (permalink) | |
Yes, it should prevent future damage but no guarantees.
#39 (permalink) | |
Second thanks for the pointers. I did a 2x2 test previously with meguiars rubbing compound then swirl remover, both worked well but of course the water etch marks just stand out more with the swirls removed. I just got into polishing so my equipment is just starting to build; currently have GG 6" polisher with 4 GG orange polishing, 3 GG red waxing pads, GG polish 1-3, GG glaze, and the DG TPP + PBA. Using only speed 4 with the meguiars products and orange pad took too long nearly 30 minutes, seemed too long and with a quick calculation it would take nearly 4-5 hours just polishing to remove all the swirls. I probably need more efficient pads. |
#40 (permalink) |
Four to Five hours is not out of line especially when you're new at it and learning. Also keep in mind that in some cases water spots are there forever. Some compounds and polishes have a long working time and some do not.......also try speed 6 on the Griot's Machine. Look into the Menzerna line of compounds & polishes. They're expensive and they work. If I could choose only one it would be the Super Intensive polish.
Autogeek Menzerna Compounds Comparison Chart
