Country: Join Date: Sep 2012
Hi i have a sports edition 2011 rav4 and i wanted to replace the side mirrors with signal mirrors, is this possible or is the port and wires different and cannot be installed? I just ordered some parts from Toyota, white side mirror caps/covers so it'll have the nice matching look, it was $140 total, but i was thinking should i order two signaled side mirrors on ebay for ~$200 then order the side mirror caps from toyota that's painted already for ~$140 instead? If it can be installed. It'll be better in the long run but if it's not possible, it'll at least make me feel better that i didn't do that instead. Thanks!
Country: Join Date: Aug 2012
I'm in the same boat as you are, but I have a 2012 Rav4 base 4cyl fwd with the 3rd row option only, and not a sport. One way you can find out which mirror plugs in your Rav is finding out if it was made in japan or canada since they have different plugs, and find out if it's plug n play (usually sport models are though). As for me, id rather just buy the mirrors from the dealer, but that's a $650 investment! There are a few threads out there with more info.
#3 (permalink) | |
Usually for my cars, i buy oem stuff when it comes to certain parts, but your method sounds nice too due to the $$$. You can also splice some wires if you know the wiring diagram, but I would try to keep it professional and authentic as possible. Again, that's just me.
Country: Join Date: Nov 2011
uEih,
I just replaced the std mirrors with heated/signal units on my 2011RAV4 Sport, 4 cyl, AWD. The key, as someone stated, is to determine where your vehicle was built. Then you will need to verify the connectors that are on your current mirrors. This requires removing the door panel on one side. The Canadian built models will use a rounded 2-piece modular connector, while the Japanese built connectors are one piece, rectangular. I prefer OEM so I purchased salvage mirrors from a yard in Ontario,Can for my Canadian built vehicle. They run around $150 -200 depending on condition. If you choose this route, be sure to have the sales guy send you clear ephotos of the part your considering to be sure of condition/connector style. I like the blacked-out look so I painted mine flat black and top coated with satin clear acrylic for a more discrete appearance. Buying prepainted is a good idea and will save you much time but it'll cost $$. BTW the heated/signal mirrors were an option for the 2011, 4 cyl, AWD, Sport model so it was a plug and play, just a matter of getting the correct connectors. Regards, GRBud |
Yeah. That's my issue. You guys with sport models have more of a chance to already have the wiring for the heated mirror option than us with base models.
#7 (permalink) | |
Country: Join Date: Dec 2012
#8 (permalink) |
So, Meander. You have the same model as I, and you have the heated signal mirrors? I was just assuming since my Rav didn't come with the wiring harness for my OEM foglights. I had to use some aftermarket kit. That is why I was thinking that if I Rav didn't come with the OEM foglight harness, then it also wouldnt come pre-wired to install the heated signal mirrors. Then just like I did with the front bumper, I just may have to take out the door panel as well to verify :/
#9 (permalink) | |
Country: Join Date: Nov 2008
Also, as a general rule of thumb, Japan-built RAV4's come with the wiring for fog lights, whereas Canada-built ones don't.
