HELP!! can't separate lens after baking... - Toyota RAV4 Forums : RAV4World.com
Old 12-11-2012, 05:57 PM   #1 (permalink)
Country: shortshooter's Flag is: United States
Default HELP!! can't separate lens after baking...
I have a 2011 and I'm trying to do my first retrofit project..
firstly, there are only 2 screws on the back I must remove, right? I removed those 2 screws, put a headlight in the oven at 220 for 15, took out and couldn't pull apart. did it again for another 15 and it still won't pull apart! Any advice?
shortshooter is offline   Reply With Quote
Old 12-11-2012, 07:22 PM   #2 (permalink)
anyone? I put it in for another 20 minutes at 200 degrees and couldn't get it to open. so now I have a heat gun...stil can't do it
Old 12-11-2012, 07:28 PM   #3 (permalink)
Country: veliksam's Flag is: United States
veliksam's Avatar
Send a message via Skype™ to veliksam
Did you remove the 3 screws? Did you pry up the black tabs? I used a heat gun and it worked just fine.
Sent from my Nexus 7
HU: Pioneer AppRadio 2 & back-up cam,
Red "SPORT" Theme Badges
veliksam is online now   Reply With Quote
Old 12-11-2012, 07:33 PM   #4 (permalink)
which 3 screws? I only see 2...how long do you leave the heat gun at one spot for?
Old 12-11-2012, 07:42 PM   #5 (permalink)
veliksam's Avatar
There is a screw in each corner (95% sure), use a flashlight if you can't see it. Don't keep it at one spot, move it around the seal continuously and slowly, after a few slow passes try separating the the lens using your prying tool.
Old 12-11-2012, 08:09 PM   #6 (permalink)
http://i1282.photobucket.com/albums/...8/IMAG0813.jpg
Look at this photo...is that the glue? it looks like a piece of the plastic that's breaking...
Old 12-11-2012, 08:10 PM   #7 (permalink)
opinions? I need to finish this soon so I can use the car...
Old 12-11-2012, 08:19 PM   #8 (permalink)
Opinion? Why on earth would anyone want to do this? I am at a loss as to why but best of luck since you can't even drive your car......great modification .
Old Bird......sometimes wise
Both with Tow Prep Package
Old 12-11-2012, 08:27 PM   #9 (permalink)
It's called a retrofit. I'm adding projectors so I can safely drive with HIDs and increase visibility
Old 12-12-2012, 01:48 AM   #10 (permalink)
Ohhh... I thought maybe you had condensation you were trying to get out of your headlight assembly. You are our first headlight baker, as far as I know. For a bit I thought there were two all of a sudden, but it turned out that was just you starting another thread.
Carbon is online now   Reply With Quote
