Just another heated, turn signal side mirror thread - Toyota RAV4 Forums
post #1 of 9 (permalink) Old 01-11-2013, 08:06 PM Thread Starter
Country: jingerale's Flag is: United States
So there are already plenty of threads on this subject, but my questions have still not been answered.
Hopefully, this can turn into a one stop shop for all side mirror thread as well as get some answers for myself.
First, for us with Base and Sport models, there are 2 connectors for the side mirrors.
7 pin for US/Canada assembled
11 pin Japan assembled
It seems the Sport models are pre-wired with working connectors. Meaning the connector already has signal and heating so adding a new mirror is plug and play. ( this has been confirmed by a few members)
Base model? My 2012 has the connector, and it seems the pins are populated. Are they working connections providing a plug and play solution? ( will find out this weekend with multi-meter).
Plug and play solutions: This is easy, purchase new mirrors with corresponding connector, either after market from ebay ( which should be anywhere from $140 to $180) a pair. Or get the OEM parts, which will probably run you upwards of $600 for a pair. From what I can tell, it's about $200 just for the housing with heated mirrors, $80 for signal lamp and another $50 for cover(matching).
I'm not gonna pay $600+ for a set of mirrors. I also don't want aftermarket stuff. If you feel the same way, then there might be other possibilities depending on the answers to the following questions.
Assuming car is pre-wired with working connections:
1. what is the difference between the Japan model and the Canadian model? 7 pin vs. 11 pin. Can the 11 pin connector be spliced to work with the 7 pin? I think it's safe to assume in both cases, 4 pins are taken by signal and heat. So does that mean the Japanese mirror requires 7 pins to do the job of 3 pins(Canadian mirror)? Are there dead pins? or is the motor simply have difference control input.
why this question? well, from my searches, it seems there are a lot more OEM (Japan made) mirrors available outside of the usually OEM part sites. For example, there are a pair of OEM Japan side mirrors with signal and heat for $90, new. This would cost $290 from most of the sites I've seen.
2. Can signal and heat be added as individual options to standard base mirrors?
This may be important to those that only want signal lamps and will provide a much less expensive way to have OEM mirrors.
We know heated mirrors can be replaced. we also know that the signal lamp is/ can be sold as a separate part. So it makes sense that the housing is identical on all mirrors. I'm assuming these darn things are injection molded, and it wouldn't make sense to have 2 molds. The signal lamp is attached to the mirror housing with 2 screws. From looking at pictures of signal mirror without cover, and non signaled mirror without cover, the housing look the same. the small bottom cover may be different.
Assuming this case, the signal lamps can be installed mechanically, but what about wiring? By looking at the mirror side connector on my base Rav4, there are only 3 pins populated. Obviously you would need 7 to make the rest of the options plug and play. can this harness be purchased? can the signal or heated mirror be hard wired/spliced?
So why these questions? Well, I don't necessarily need heated mirrors, but I would like turn signals on my side mirror. I want the cheapest solution while still keeping the OEM mirrors.
There are some costs that can not be avoided, e.g. painted covers. You can buy primed and paint them, or just buy matching covers, either way, that $90-$100 has to be spent.
But money can be saved if couple things can be done. Cheapest for me will be simply adding signal lamps. Worse case is $180 for a pair of lamps and bottom covers. Second cheapest will be making 11 pin Japanese mirrors work with my 7 pin connector at just over $200(better option value wise since this has heat).
Edit: Just to add, the reason why I want OEM mirrors is due to the reports of after market mirrors having vibration problems. Now, another option can be, if possible, purchase the cheapest after market from ebay. remove side signal and wiring harness, then transfer onto existing mirror? not sure if this can be done, but why wouldn't it be possible?
7 pin connector
11 pin connector
base mirror without cover
mirror with signal. note the wired connector coming from the mirror to the lamp.
jingerale is offline
post #2 of 9 (permalink) Old 04-04-2013, 05:19 PM
Country: Pyramid_Head's Flag is: United States
I've been dissecting aftermarket mirrors so i can also do some research and find out if it is possible to do it the inexpensive way. So far, i have made the aftermarket mirror's motor to work, but i havent figured out why the turn signals do not work. Also, the inside of the morrors cannot be swapped. They both have different mounting brackets and the inside dimensions are way different. So far, it has been the worse $150 i've spent on a pair of signal/heated mirrors. My advice so far is to stick with OEM.
Or you can buy some of these:
http://www.ebay.com/itm/09-11-US-Bui...ht_1998wt_1129
Pyramid_Head is offline
post #3 of 9 (permalink) Old 04-04-2013, 08:21 PM
pico's Avatar
The more expensive mirrors might be surface mirrors, or something close to it compared to the cheap ones.
pico is offline
post #4 of 9 (permalink) Old 04-04-2013, 08:51 PM Thread Starter
I ended up with OEM mirrors for Japan made Rav4s. I spliced all the wires to make them work. Total cost was $300 for matching silver covers.
Love them!
post #5 of 9 (permalink) Old 04-04-2013, 09:26 PM
Yeah. I was trying to do that with my Rav, but i just couldnt make the turn signals to work. I put everything back together and i'll try to attempt it first thing tomorrow. By the way, can you give me some pointers on how to wire everything up? Im not sure why the motor worked, but not the turn signals. i also have the 11 pin connector mirrors.
post #6 of 9 (permalink) Old 04-05-2013, 03:58 PM Thread Starter
well, assuming you have 7 wires coming out of the car wire harness.
I used a multimeter to find out which of those 7 were heat and signal.
Then I spiced the motor connections and put on male connectors. that way, I don't break the connection to the factory connector. If I need to put back the original mirror, I can still use the factory connections.
Cut the wires on the factory harness for signal and heat, put male plugs on them. Female ends on the mirror.
That's all. Hope it helps.
post #7 of 9 (permalink) Old 01-13-2017, 06:22 PM
jhb
Country: jhb's Flag is: United States
Just in case someone is still interested in installing heated mirrors on their base model ... I was able to add the missing wiring for heated mirrors after lots of effort. However, after looking into it, I did not feel that the effort to add the wiring for the turn signals on the mirrors was worth the effort.
Here's what I learned ...
1. Some wiring is in place for the mirror heat circuits, but not all. The wiring is in the dash and in the doors. You must install one wire for the driver side mirror heat from the E74 junction connector in the driver side footwell to the HE2 driver side door connector also in the driver side footwell. You must install one wire for the passenger side mirror heat from the E74 junction connector in the driver side footwell to the GE2 passenger side door connector in the passenger side footwell.
2. Some wiring is in place for the mirror turn signal circuits, but not all. I decided it was not worth the effort to install the missing turn signal wiring, so I did not investigate it further.
3. You cannot buy heated mirrors without turn signals for the 2009-2010 models, so I bought a pair of 2008 model year aftermarket heated mirrors without turn signals with the correct connector type for my car (sometimes referred to as Japan built). Using aftermarket mirrors was a mistake for the reasons listed above by jingerale and Pyramid_Head.
4. The 2008 and 2009 mirrors are wired different, so the wiring must be changed to match the 2009 model year wiring. This was easy to do.
5. The aftermarket mirrors vibrated a lot, so I installed heated mirror glass in the OEM mirrors, added the two wires to the mirror wiring and connector, and reinstalled both mirrors. This was also relatively easy to do.
If I was to do it again, here's what I would do ...
1. Leave the passenger side mirror as-is. (The heated mirror on the passenger side is not worth the effort.)
2. Replace the unheated mirror glass in the OEM driver side mirror with heated mirror glass. Add the two wires to the mirror and to the mirror connector. (This prevents the problems with the aftermarket mirrors.)
3. Install the wire for the driver side mirror heat from pin 3 on the E74 junction connector to pin 9 on the HE2 driver side door connector. (You need two pins for the connectors for this ... PN 82998-12340 and PN 82998-12330. You also need about 6 inches of 20 AWG wire--The factory wire color is pink in case it matters to you.)
Feel free to PM me if you want to try this for yourself and I'll send you the pages from the wiring manuals to help you do it.
Live in fear, you’ll never be disappointed
2009 4WD Base (90K) and 2013 AWD XLE (25K)
jhb is offline
post #8 of 9 (permalink) Old 01-19-2017, 02:08 PM
Country: kiano's Flag is: United States
Interesting write up. Maybe I missed it but where did you buy the heated glass? Pictures of the before and after would be nice.
kiano is offline
post #9 of 9 (permalink) Old 02-03-2017, 04:22 PM
jhb
I bought and installed aftermarket heated mirrors from 1A Auto in Westford, Massachusetts, a few miles out of NH. When I tired of the vibration, I removed the heated glass and installed it in my OEM mirror housing with black silicone / RTV. The black silicone covers the few small gaps (1/16-1/8") between the edge of the mirror and plastic frame, so you can't easily notice they have been replaced. Regardless how I did it, I recommend you buy the OEM (or equivalent) replacement heated mirror glass in the plastic frame. The glass and frame snaps in and out of the mirror housing. I think you can find them on eBay for about $35.
jhb is offline
