How to save your high beam bulbs from DRL, add aftermarket RAV4 specific DRL's! - Toyota RAV4 Forums : RAV4World.com
Old 01-15-2013, 03:39 AM   #1 (permalink)
Country: veliksam's Flag is: United States
veliksam's Avatar
Send a message via Skype™ to veliksam
Default How to save your high beam bulbs from DRL, add aftermarket RAV4 specific DRL's!
I bought myself a set of nice Phillips bulbs for my high beams a few months back, then I realized that my drl function will shorten the life of my $35 bulbs. So I set out to find aftermarket drl's for the 4.3, I found a few options:
New Toyota RAV4 LED daytime running head light/lamp 2pcs-in Light Source from Automobiles & Motorcycles on Aliexpress.com
CAR Specific Toyota RAV4 2012 LED DRL,LED Daytime Running Light + Free Shipping By EMS,Newest Type!!!-in Daytime Running Lights from Automobiles & Motorcycles on Aliexpress.com
CAR Specific Toyota RAV4 2011 LED DRL,LED Daytime Running Light + Free Shipping By EMS,Newest Type!!!-in Daytime Running Lights from Automobiles & Motorcycles on Aliexpress.com
I went with the First option because I liked the look and dual functionality (they switchback for turn signal). Installation is pretty simple but time consuming. I taped the turn signal wires from my headlights for the turn function and I wired the drl function to acc power and also a fog light switch. So if I want them off I can switch them off anytime but still retaining the turn function. I removed my front bumper in order to install the drl's and route/conceal the wires nicely, no drilling is required because they snap in place where the black plastic garnish/mesh was removed, plus they have 3m tape for extra assurance. Once I had my nice new drl's ready, I went ahead and removed the brown 5 pin relay and installed the 4 pin headlight relay, the result was no more killing my nice bulbs slowly. Had I already purchased the TIS software and cable I could have disabled them from the ecu and saved $4 from having to buy the 4 pin relay
Here's how they look on my RAV4 (these pics are from before I had them wired):
Anyways, I thought my fellow forum members might find this info useful, if so then just hit the "thanks" button if not then
HU: Pioneer AppRadio 2 & back-up cam,
Red "SPORT" Theme Badges
veliksam is online now   Reply With Quote
The Following 5 Users Say Thank You to veliksam For This Useful Post:
doane2u (03-22-2013), J3T (03-03-2013), jingerale (01-15-2013), JuneBug (01-15-2013), RickB (02-22-2013)
Old 01-15-2013, 11:07 AM   #2 (permalink)
Cool! Now if only we could see what they look like when lit up.....
Old 01-15-2013, 01:44 PM   #3 (permalink)
Country: jingerale's Flag is: United States
so I'm trying to figure our how this "switch to turn signal" works. You are getting power from 2 sources. 1 is turn signal, and ACC with a switch. Assuming, common ground, with power leads from both sources.
when the switch is off, it's easy to understand, there's only turn signal. But when the power is on, and you turn on the turn signal, how does interrupt the constant power from ACC?
jingerale is offline   Reply With Quote
Old 01-15-2013, 07:04 PM   #4 (permalink)
veliksam's Avatar
I will post some pics tonight
Old 01-15-2013, 07:09 PM   #5 (permalink)
veliksam's Avatar
I'm sorry but I have no idea how the installers did it :D I think there was also a relay involved. The only thing I know for sure is that they got power for the turn signal function from the headlight turn signals. I'm sure any one with decent wiring knowledge would be able to do it. I'm not very good with wiring
Btw, each drl has this little black box on the wire so I think that is what does the trick. I only did the routing of the wires.
Old 01-15-2013, 07:17 PM   #6 (permalink)
ok, thanks. so it was the installer that added the feature? or did it come with the feature and the installer installed it using provided instructions.
thanks
Old 01-15-2013, 08:00 PM   #7 (permalink)
veliksam's Avatar
thanks
Well, they didn't come with instructions. Here is what happened, at first we didn't know which wires were for the turn and drl, so he tested them with a battery and one wire was for the turn, one for the drl, and one was the ground. All of these wires pass through a little black box that's attached to the wires, my guess is that the little box does the switching. When you put on your turn signal it cuts the power to the white drl and gives power to turn signal Amber drl. The turn signal feature is already built in, also if you don't want to use that feature then you can just leave the turn wire disconnected. I will post pics in the next few minutes.
The Following User Says Thank You to veliksam For This Useful Post:
Old 01-15-2013, 08:28 PM   #8 (permalink)
veliksam's Avatar
Additional pictures of drl & turn signal function added to First post
Old 01-15-2013, 09:16 PM   #9 (permalink)
Perfect...thanks for the info. that's enough for me to get a set. Too bad I have to order it from China, seeing how I will be there next week.
Old 01-15-2013, 09:19 PM   #10 (permalink)
veliksam's Avatar
Unfortunately there are no US sellers for this item, I've looked everywhere.
