#1
Hi Guys
My v6 Rav4
2011 has rust inside the door (driver door).... :surprise
other door are ok...
what do you think about that ?
see the dealer ?
unscrew the screw and fix it myself ?
bear in mind that im more HANDSOME than HANDY
THanks
See less
See more
1
#3
Is there some kind of warranty on this kind of damage?
Otherwise, since it is in area which is not very visible:
Sand down, apply rust converter (or use POR-15), primer, spray paint colour matched paint
#4
Also check the weather strip that should be against the window to keep water out.
#5
the dealer told me its not cover under warranty
Can i just remove the screw to see what the domage ?
or the screw is attatch to something else ???
#6
UPDATE:
this is what it looks like:
what yall think ?
#7
No worries. Just spray some of your favourite anti-rust oil spray e.g. Krown, Corrosion Free, ... Do the same at all 5 doors, once a year.
#8
HI yall
I talk to some poeple and i my try this ... than paint it black (as Jagger once told me ...)
#9
No need to make a project out of it when a couple of drops of any kind of oil will penetrate and stop the rust for years.
#10
Take my word and Dr. Dyno's for it. I love a painting project. This is one is not worth the effort.
