Country: Join Date: Aug 2007
As part of my DVR install, I want to install a module which will provide 12VDC to my DVR even when the car is turned off, but also monitor battery voltage in order to cut off power should the battery get low.
I uploaded the manual here (only 4 pages, 4MB), was hoping for some tips as to make this process very easy. Quick instructions say:
So it's a pretty easy process. I do have experience dealing with installing electronics (signal mirrors, CarPC, etc.) in general, just not in the RAV4. Should I get/use fuse taps? What's the best location for ground? Are there better ways of doing this? Thanks guys!
General G-MAX AS-03 235/55R18 summer tires Nokian Hakkapeliitta SUV5 225/70R16 snow tires SoundFX antenna Husky floor liners CompuStar Pro P2W9000FM-AS Canister shield OEM mud flaps Bluetooth OBDII+Torque Griffin BlueTrip AUX + Pocket Amp 2 BlackVue DR400G-HD DVR + Power Magic Pro |
Country: Join Date: Sep 2011
RAV4 4.3. uses these low-profile mini fuses. I had a hard time finding wire taps fitting this size. I ended up soldering a piece of wire to a low-profile mini-fuse!
A regular mini fuse might fit but then the fuse box cover would not fit . |
For ground, I used a bolt in the driver footwell, near the left foot.
I am not sure if it is the best ground but works perfectly for my foglights and heated seats. |
I'm guessing I will have to get some of these fuses with a pigtail (item # is 330692566963).
Do you have any pictures of the soldering job? Never had to deal with fuses this small before.
Are you still able to put the cover back on? What gauge wiring did you use? I took the cover off today, and there is 0 room. I need an 'always on' fuse, 'on when running' and ground. I don't think I can pull that off without leaving the cover off (or modifying it).
#8 (permalink) |
No other suggestions? Anyone?
#9 (permalink) |
Do you remember which fuse you tapped for always-on 12VDC? The only 'tap' product on the market is $25 shipped via eBay, which is just too much, so I need to come up with another solution. I do have basic soldering experience, but am mostly concerned that the dealer will freak out when he sees this setup, and give me a difficult time.
