make a RAV4 rear sleeping bed platform for two, step-by-step walk thru Read more: h - Toyota RAV4 Forums : RAV4World.com
Old 06-03-2012, 06:42 PM   #1 (permalink)
Country: klm4755's Flag is: United States
Default make a RAV4 rear sleeping bed platform for two, step-by-step walk thru Read more: h
Enclosed is a step-by-step walk thru to build a 6 foot 4 inch flat cargo area that would facilitate a 2 person sleep area. The rear cargo area (behind the drivers seat) has a length of about 5 foot 4 inches. The desire would be to extend this length by a foot or so to allow 2x standard backpacking mats side-by-side to accommodate a flat sleep area within the RAV4. The goal of the build includes:
1. Design and fabrication of a sturdy, stable platform.
2. Can be build with common materials and tools.
3. The platforms can be stowed (when not in use) within the under-floor hatch, out of sight.
4. Can be set-up without too much hassle or time.
5. As a secondary consideration, is adoptable for the 2011 Toyota Prius also. The RAV4 has about the same cargo length of the Prius. The design will start with the Prius then be adopted to the RAV4.
NOTE: The RAV4 adoption is at the end of the walk thru
The annotation describing each figure will occur at the bottom of the picture.
View of prius cargo area with back seat folded down
5 foot 2 inch (flat distance) distance from rear of cargo to folded back seat rest
1 foot 5 inch excess distance for platform. Just need to consider design options that meet the criteria listed above.
Camping mat at 6 foot long 20 inches wide
another compact inflatable backpacking mat
20 inches wide with added pillow sleeve. add clothing between mat and sleeve to make a pillow
mat in cargo area of prius
overhang needing support, about 1 foot
support platform .5 inch laminate oak from Home depot
Mark a 22 inch x 15 inch section
quick fit, will need to mount here
.125 inch thick by 2 inch wide Aluminum strap, from Home Depot
Mark for trim 4 inch length's 3x total parts
Cut with band saw, fine tooth blade
round sharp corners
deburr parts
use this tool to determine mounting fastener grip length
fasteners from Home Depot
diameter of threaded shank at .1845
Drill slightly larger than fastener shank at .186 inch
set-up for drilling holes
klm4755 is offline   Reply With Quote
The Following User Says Thank You to klm4755 For This Useful Post:
KuddlKat (01-01-2013)
Old 06-03-2012, 06:43 PM   #2 (permalink)
drill holes, 2x holes per part, .5 inch from edge of platform
using flush manufactured head fasteners, need countersink in straps
use this piloted countersink tool bit, 100 degree
machined straps completed
close-up of fastener installed
deburr drill exit side
mount straps on platform
quick fit check in prius, A-ok.....
add a 4 inch angle to the middle strap, the extended flange will fit between the rear seatback and the head rest, stabilizing the fore-aft movement of the platform
drill
mount like this
Now for the front platform attachment, I'll use the passenger headrest as the attach point
strap kit items
100% nylon thread, 3/4 inch buckles and 3/4 inch nylon straps
stitch the part like this, one hard attached female buckle, one threaded female buckle, one adjustable male buckle.
melt the ends of the strap with a soldering iron
like this gives the polished look
hand sew the end of the female buckle to the nylon strap
finished product, repeat 3x more times total
length ~9 inches
strap slots in the platform to thread in the 3/4 nylon strap, use router bit from dremal tool
hard attach the nylon strap at ~18 inches, add male adjustable buckle
finished product, now for mounting
Old 06-03-2012, 06:44 PM   #3 (permalink)
1. Remove the rear shoulder restraints, it's ok they re-attach easy, shift fwd seats all the way fwd and backrest fwd.
2. fold rear seats down
3. Attach the headrest buckles
4. mount the platforms, attach the headrest buckles, adjust front strap length till level
rear view
about 6ft 4 inches of total usable length
add floor and/or rear cargo mats over the joint as an option
backpacking mats inlayed
View from front seat
view from outside
with cargo cover, for some privacy
gap between mat top and cargo cover
inside view
RAV4 rear with seats down
5 ft 4 inches from rear to top of folded rear backrest
platform installed, no modifications to platform by the way, just so happens to fit
view of the angle added to stabilize the fore-aft movement, same as prius
both platforms installed
rear view
mats in RAV4
front side view of mats on platform
view from passenger seat
platform ready to go under cargo storage area of RAV4
fits well in RAV4, no issues
Prius storage, no issues
My intent is to keep one platform in the Prius and one in the RAV4 for emergency usage and transfer one to the other car for a long distance road trip.
Old 06-04-2012, 04:53 PM   #4 (permalink)
Country: Tonyride's Flag is: United States
Tonyride's Avatar
Interesting but the first car you showed looks a lot like a Prius.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
Tonyride is offline   Reply With Quote
Old 06-04-2012, 05:26 PM   #5 (permalink)
Although I would have no use for such a contraption I absolutely admire the work and thought that went into both projects. I'm one of those that cannot draw a straight line on paper with a ruler and a pencil so you're a wizard in my eyes. Well done
Old Bird......sometimes wise
Both with Tow Prep Package
Old 06-04-2012, 05:36 PM   #6 (permalink)
Country: hawkeye16's Flag is: United States
Sweet neoair mattresses!
hawkeye16 is offline   Reply With Quote
Old 06-04-2012, 08:58 PM   #7 (permalink)
The first car was a Prius. It just so happened the platform fit the RAV4 aslo without modification.
Keith
doane2u (09-28-2012)
Old 06-12-2012, 06:27 PM   #8 (permalink)
Country: Truck57's Flag is: United States
Cool. and awesome camo on that bike!
Truck57 is offline   Reply With Quote
Old 09-27-2012, 03:14 PM   #9 (permalink)
Country: Tedbird's Flag is: United States
KLM 4755 Welcome aboard a super Forum. You did an excellent job. I am in the process of planing a sleeping/camping area in the back of my RAV so i don't have to mess with my Pop-up trailer. THANKS for sharing.
08 RAV4.3 V6 4wd Ltd. Former rides: 04 Pontiac Vibe (Toy. Matrix); 54 XK120MC Jaguar Roadster; 65 Mustang; 61 Chev. Corvair; 54 Chev. convertable; Miscellaneous.
Tedbird is offline   Reply With Quote
Old 09-28-2012, 12:57 AM   #10 (permalink)
doane2u's Avatar
KLM 4755 I have no use for it, but that's a great project and you really illustrated it well and clearly.
I think I would be concerned about the three metal tabs facing the rear and their rubbing on the vinyl on the back of the rear seats that are folded down from movement of people in the bed. Maybe you could plastidip them? Also, the front edge of the plywood looks like it will rub on the back of the front seats... maybe add some sort of soft plastic molding strip to the front edge?
2010 Toyota RAV4 V6 AWD Sport, Magnetic Grey/Charcoal, Extra Value Pkg, Sport Appearance Pkg, Tow Pkg, BlueLogic hands free
doane2u is offline   Reply With Quote
