When I use my remote to open my car my hazards blink, and when I turn on my headlights they turn on too, so they work then. But then when I put my hazards on or my turn signal on they don't flash. I did try to put on an LED bulb for my turn signals so I don't know if that's the problem. I thought LED bulbs drain less battery.
It's your fuse, it's burnt. You probably blew it when trying to put them in the front sockets. This has happened to me on my 4.3 a couple of years ago.
If you want a dual filament (turn signal+ clearance light) LED bulbs in the headlights you'll need a flasher relay and a certain type of dual filament bulb called SACK or CK.
Just do a Google search for 7443 SACK LED and you'll find what you need.
For the rear turn signals (in the tail lights) you don't need SACK, just a regular type led will be fine.
Or I could be wrong and something else is the matter.
Did you just put the LEDs in? With or without a resistor? I understand flashers don't work with unmodified LEDs, but could be wrong. Put the old bulbs in and check again.
Hmm that's what I thought, might be the hazards fuse. And yeah I put the LED in and tried the hazards and turn signals and it didn't work. Then I put the regular bulbs in and it still wouldn't work. They would only flash when I unlock the car.
