| View Poll Results: Poll: Do you have the dreaded steering knock/popping sound? | |||
| Yes |
158 | 66.39% |
| No |
80 | 33.61% |
| Voters: 238. You may not vote on this poll | |||
If you have the knock, please list your vehicle (Engine: V6/4cyl, Drive System: 2WD vs. AWD, Trim Model: Base, Sport, and Mileage). If you have had any work done to remedy the problem, please list what that was and the result.
I'll start: Engine: V6 Drive System: AWD Model: Base Mileage: 5K Work done: We took the RAV4 in to Middletown Toyota in Middletown, CT. They replaced the strut mounts and struts on both the driver's and passenger's side, and then realigned everything. Result: Still knocking/popping. It does seem to be getting worse (more frequent, louder). I'm definitely concerned from a safety standpoint. Thanks, DJ --------------------------------------------------------------------------------- Moderator edit: TSB has been released |
Four attempts at two dealers. Both bushings and towers replaced, noise is still there. Was told by service rep that Toyota has a handfull of cases on this that they are trying to sort out. Toyota KNOWS they have a design flaw and at the moment have no fix for this.
Currently in arbitration with Toyota to get a new vehicle.
- 2008 Outback Ltd. - L.L. Bean Ed. - 2006 Classic Silver V6 Sport. Ed. RAV4 - (sold) |
#4 (permalink) | |
HTH - DJ |
Sounds like popcorn popping under the hood while taking low speed turns left or right...
#8 (permalink) |
Country: Join Date: Jan 2006
ok.. so far.. Is there any 4 bangers with it??
======== Defender of the 4 banger!!!! http://mustangattitude.com/cgi-bin/s.../2007_00010_01 <= website! |
#9 (permalink) |
RAV4, Limited
V6 Auto trans 2WD Current mileage: 3300 Getting the same front suspension "knock" when going over ANY speed bump or bi-level road surface. Most noticable on the passenger side. |
#10 (permalink) |
Yes, that knock is annoying from a new car. It is like worn shocks or something bad with the tie rods. If I go at city speeds and hit a bump or joints on the road the suspension knocks. It is like taking a hammer and hitting the strut.
I wonder if it is caused by the SRS system, since the wheels for a split second lose traction while in the air. |
