Constant rotational noise while driving. - Toyota RAV4 Forums
post #1 of 20 (permalink) Old 05-21-2009, 03:10 PM Thread Starter
Hi,
2006 RAV4 V6. Here is the problem. Upon acceleration I can hear a rotational sound coming from the back end. As I increase speed, the sound speeds up and produces a higher pitch. The reverse sound happens with lower pitch as I slow the vehicle down. The noise stops when the vehicle is stopped. The sound is constant and is not affected by turning, gear shifts or 4x4 lock (lock under 40km). The sound has become louder over a 6 month period and I have not had it in for pro-help yet. I would like some help with narrowing this problem down before hand. I have searched here and I don't believe this problem is the ECM drone. It is not tire related and it is not the roof rack vibration or the fuel pump hum.
Any takers? Thanks,
Herk
herk is offline
post #2 of 20 (permalink) Old 05-21-2009, 03:30 PM
Re: Constant rotational noise while driving.
Originally Posted by herk
Hi,
Any takers? Thanks,
Herk
My guess would be a wheel bearing going out.
JuneBug is offline
post #3 of 20 (permalink) Old 05-21-2009, 03:57 PM
What condition is the differential oil in? When did you last have it serviced? Was there anything on the drain plug magnet?
INDYMAC is offline
post #4 of 20 (permalink) Old 05-21-2009, 04:59 PM Thread Starter
INDYMAC,
I have 80000 miles on it and no diff service as of yet. I will look into your suggestion and post back.
Herk
herk is offline
post #5 of 20 (permalink) Old 05-21-2009, 05:27 PM
The change interval for the rear diff and transfer case fluid is 64,000 km. Probably should be done even if that doesn't turn out to be your problem.
bmorton is offline
post #6 of 20 (permalink) Old 05-21-2009, 07:26 PM
friendly_jacek's Avatar
How you do know that? Defective tire with snapped belts or internal separation can sound like that and last a while before it blows up. Uneven tire wear can also produce noisy tire. Rotate tires to exclude that.
If diff was not serviced yet, it needs to be checked also. However, the diff noise would change with acceleration and disappear at low speeds.
No change with turning or loading excludes bearing noise.
friendly_jacek is offline
post #7 of 20 (permalink) Old 05-21-2009, 11:26 PM
Country: RAV N US's Flag is: Canada
RAV N US's Avatar
Can you get get rear up so that you can spin the wheels? Then listen for it as you spin them.....
2008 V6 Sport 4WD Flint Mica
RAV N US is offline
post #8 of 20 (permalink) Old 05-21-2009, 11:47 PM Thread Starter
Thanks all for the help so far. I am going to tackle a few of the suggestions tomorrow. I will do the tire rotation because they need to be anyway. I have directional tires so they go front to back, back to front which will completely put tires to rest. The spinning tires idea is interesting and that will be easy. I checked for any leaks and as far as I see there are none whatsoever. The rotational noise sounds like a computer cooling fan going bad that has the magnetic push pull operation (much louder though). I am also going to do the differential oil change and check for debris. Oh and one other thing, it does it while driving in reverse as well.
Thanks again for the suggestions so far,
Herk
herk is offline
post #9 of 20 (permalink) Old 05-22-2009, 07:17 AM
Country: manu001's Flag is: United States
Should be very careful when doing so on a 4WD vehicle equipped with Tracction control... I have not tried it on my 4WD RAV, but i suspect that the Traction control may start applying brakes on the rear wheels and transferring power to the Front wheels, and the car would move!!
manu001 is offline
post #10 of 20 (permalink) Old 05-22-2009, 09:13 AM Thread Starter
manu001,
I took the suggestion from RAV N US to spin the tires with my hands while car is off. Thanks for the polite cautionary note though. That is an interesting thought of what the "brain" would control.
Herk
herk is offline
