#141 (permalink) |
I also had the CEL, VSC and 4WD lights. The RAV also exhibited a slight bucking on the highway. Dealer said they pulled about 8 error codes but felt that two engine coils were causing the rest of the code errors. After replacing two faulty coils the rest of the error codes went away. As did about $400 from my wallet.
#142 (permalink) | |
Country: Join Date: Jan 2010
Learn about your RAV4, it'll save you $$$.
#143 (permalink) |
my rav4 had the same problem been driving around with all three lights on then a couple days ago i notice that when i start the car and wanted to take it out of park it was not moving i had to be pressing the shift botton. yesterday i was driving the car around and i stop switch it off and when i tried stating it and it would not start i taught it was my battery so i got a jump and it started up ,, this morning i took my car to get the battery check and it was ok running strong so i took it to my electrician i told him i was having an ignition problem as my battery was fine he checked every relay and fuse all was well until i told him to check the switch that was on top of the break pedal , my rav is a push button start & stop while he was there checking the switch i notice i was getting the green light in the start button which was then going on an off , when hi did his check the switch was bad he pulled it up cleaned it up and then put it back in it started working fine all lights went away and i am now looking for where i can get a new switch to buy
2006 Rav4 1998 Rav4 |
#144 (permalink) |
Country: Join Date: Apr 2011
well MY fix was short lived, CEL, TRAC and VSC are back on.
CEL = P0606 VSC , flashed 5 then 1 = 51 P/S, flashed 4 then 1= 41 |
#145 (permalink) |
Okay, this post got me to read your "HELP" post for the background.
Let's start over. First, please put your vehicle info in your signature so we don't have to hunt for it. There are a lot of members with a lot of problems. We can't remember them all! Second, ignore the Skid Control ECU codes until you fix the CEL code set by the main ECU. I've found the Skid Control ECU can set many codes before the TRAC, 4WD, or VSC lights appear. And simply restarting the engine often turns them off even tho the 4-13 jumper still shows the same Skid Control ECU codes. But none of this is pertinent until you resolve the CEL code.
| The Following User Says Thank You to Dr. Dyno For This Useful Post: | UWISHU1 (10-12-2012) |
#146 (permalink) | |
OK I just got back from clearing the ECU codes with a SCAN tool. Also discovered the alternator is not putting out the ideal voltage with a load on the charging system. Have to special order a new one so it'll be a few days before I can report back.
2006 Rav 4 Base V6 2WD 3.5 liters of fury! 2011 Mustang GT Brembo Pak 2001 Mustang GT Honey Badger Pak |
#147 (permalink) |
Country: Join Date: Nov 2008
James __________________ 2008 Limited V6 2WD "The Silver Bullet" •Tow Prep •Autodim mirror w/compass •Wade deflector •Weathertech visors •BluLogic Bluetooth •QuickLift hood struts •Auto door locks • (((XM))) radio •Homelink •Unswitched 12V outlets Last edited by JuneBug; 10-12-2012 at 09:42 PM. |
#148 (permalink) |
Country: Join Date: Jan 2013
So, I have a few things in common with the rest of you here. I have the cursed three lights (CEL, VSC, 4WD) show up after hopping in the car while doing some shopping. I had just been skiing earlier today, and then filled up on my way down from the mountain
Oh, and I had the car in for regular maintenance last week and everything checked out fine Of course, there is no mechanic I can call on a Sunday evening. Fortunately I found this forum. So, I know I can at least get to work and then have it checked out later. I am really hoping whatever it is is covered under warranty because I just paid $500 for its 60K service last week.Yes, I went out and checked the gas cap. It seems fine, but will make sure the dealer checks it as well.
Teresa '08 Rav4 Sport V6,My first Toyota after having minivans for the past 15 years and loving it. Last edited by Tedaii; 01-07-2013 at 12:12 AM. Reason: add signature |
#149 (permalink) |
OK, since you don't have the check engine light, it means a code has been stored in the anti-skid ECU. Probably what happened is some grime or debris you picked up on the way down the mountain got stuck on one of your wheel speed sensors. Once the sensor is cleaned off you should be back to normal.
#150 (permalink) |
Actually, the CEL did come on with the others. Strange thing happened. I had checked the gas cap before going to bed last night. Today I ended up driving two 2 cycles on my way to work. When I got back in my car to go home, the warning lights had all gone out. My guess is on the gas cap not being tightened properly when I fueled up. I was all set to go to the dealer this evening after work. Now I don't have to
I didn't even have to disconnect the battery cable since the system seemed to reset itself. Nice to know for future reference.
Teresa '08 Rav4 Sport V6,My first Toyota after having minivans for the past 15 years and loving it. |
