#41 (permalink) |
Country: Join Date: May 2009
I'm going to be changing the oil in my sister's trucklet tomorrow (or Sunday if the weather doesn't cooperate). I'll check it at shutdown +5 and have my BIL check it the following morning and let y'all know what I find.
It's actually my sister's, but I'm the family wrench. |
#42 (permalink) |
Country: Join Date: Jun 2006
Has anyone confirmed that difference between hot and cold oil level?. I have been checking oil several times this weekend and see no difference between hot and cold (next morning).
#43 (permalink) |
Country: Join Date: Jun 2012
Usually "cold" oil level is higher than hot. More oil has had time to drip down to the pan , say overnight. That's been my experience.
Checking the oil when the engine is hot is "industry standard" so everyone is on the same page. Kevin
#44 (permalink) | |
Country: Join Date: Sep 2010
Tom
2010 RAV4 Limited 4WD V6 Blizzard Pearl To live only for some future goal is shallow. It's the sides of the mountain that sustain life, not the top." — Robert M. Pirsig Illegitimi non carborundum |
#46 (permalink) |
Country: Join Date: Jan 2011
Bringing this thread back to life.. it is somewhat related to what I am experiencing...but no dealership is in this story since I do my own oil changes.
I have inconsistent and inaccurate readings of the oil level with my dipstick (08 sport I4). Plain and simple (but really silly to ask) what is the proper procedure to measure the oil level??? cold engine, hot/warm engine (definitely engine off in both cases), but most intriguing is what direction should the raised notch(s) face when inserted? I dont have pics with me (soon to be posted) see the OPs pics for reference. I am experiencing weird readings in which either side of the dipstick will give different readings in the same pull... raised notch will show 1/2 full, backside at full or more.. WTF??? Even if I do a really quick insert and pull to read i see the same pattern. same when inverting the notch. |
#47 (permalink) |
Country: Join Date: Oct 2009
pepepeter, if you have different readings on opposite sides of your dipstick, you should use the lower one. The higher side may have oil smear from rubbing against some internal surface. Meanwhile, it's practically impossible for the dipstick, dipped in oil, to have it partially wiped clean from the action of removing the dipstick.
#48 (permalink) |
Country: Join Date: Jan 2009
Rav4two, that makes sense to use the lower if you can see two levels.
I considered roughing up the dipstick or even drilling tiny holes to be filled with oil. It can be hard to see clean oil, plus the surface of the dipstick does not seem to hold an oil film well.
2009 V6 4wd Base |
#49 (permalink) |
thanks guys its what i figured... however, this means the oil consumption is back and yes I am using mobil 1 full synthetic 5w-20...
#50 (permalink) | |
Country: Join Date: Feb 2012
