P0356 Code plus 7 other codes - (Might be a bad coil.) --2006 V6 61,000 miles - Toyota RAV4 Forums
post #1 of 45 (permalink) Old 09-15-2010, 09:03 PM Thread Starter
I have all these codes on my 2006 V6 Sport
P0300, P0301,P0302,P0303,P0304,P0305,P0306,P0356
Check Engine Light on
Cruise and VSC are disabled.
Looks like it may be a bad coil on number 6 cylinder. Going to swap with another and reset to check.
P0351
Ignition Coil "A" Primary / Secondary Circuit
1. Ignition system 2. Open or short in IGF1 or IGT circuit (1 to 6) between ignition coil with igniter and ECM 3. No. 1 to No. 6 ignition coils with igniters 4. ECM
P0352
Ignition Coil "B" Primary / Secondary Circuit
P0353
Ignition Coil "C" Primary / Secondary Circuit
P0354
Ignition Coil "D" Primary / Secondary Circuit
P0355
Ignition Coil "E" Primary / Secondary Circuit
P0356
Ignition Coil "F" Primary / Secondary Circuit
P0300
Random / Multiple Cylinder Misfire Detected
1. Open or short in engine wire harness 2. Connector connection
3. Vacuum hose connection 4. Ignition system 5. Injector
6. Fuel pressure 7. MAF meter 8. ECT sensor 9. Compression pressure
10. Valve clearance 11. Valve timing 12. PCV valve and hose
13. PCV hose connections 14. Air induction system
15. ECM
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
7tisix is offline
post #2 of 45 (permalink) Old 09-16-2010, 02:39 PM
Country: earthrealm's Flag is: Nigeria
earthrealm's Avatar
Send a message via Yahoo to earthrealm
well, y dont u get a scanner, costs abt 80 bucks or less, me thinks u cud damage ur onboard ecu if u short the wrong pins
2005 4runner auto sr5 4wd v6 galactic gray.
2003 rav4 auto I4 4wd titanuim silver
earthrealm is offline
post #3 of 45 (permalink) Old 09-16-2010, 07:01 PM
You changed your original post so much that my original answer no longer made any sense, so I've deleted it.
RF Overlord is offline
post #4 of 45 (permalink) Old 09-16-2010, 08:36 PM Thread Starter
This helped --> http://www.rav4world.com/forums/viewtopic.php?t=21976
Swapping now and will see if new codes come up.
Another coil failure. --> http://rav4world.com/forums/viewtopi...highlight=coil
7tisix is offline
post #5 of 45 (permalink) Old 09-17-2010, 01:16 PM Thread Starter
Yeah sorry about that... I would hate for somebody to try that and possibly fry their ECM. Since it was not beneficial info for the forum, I changed it.
7tisix is offline
post #6 of 45 (permalink) Old 09-17-2010, 02:49 PM Thread Starter
Pulled coil on cylinder 6 and removed spark plug. Disconnected wire to fuel pump #6. Had the coil in my hand with the spark plug attached as the car was cranked. I didn't see spark, but I think it was a bad ground i was using. I did see spark for a second so coil is at least somewhat good. Swapped coil with the one next to it, so if a code comes up, it will be a different one. Cleared Check Engine light by removing negative battery cable and depressing my brake pedal.
Warmed up Rav, no codes. Test drove 5 miles with some heavy acceleration. No codes yet.
About to run some errands. I'll update later.
7tisix is offline
post #7 of 45 (permalink) Old 09-17-2010, 10:23 PM Thread Starter
Check Engine is back. Codes all same except P0355 instead of P0356 since I swapped coils with the one next to it... definitely the coil.
Bought online for $35 shipped ground. Advanced Auto would be $57 plus tax, Autozone $119 plus tax.
The coils are attached with one cable connector and one bolt. Super easy to do this. I will have the new coil in place inside 3 minutes time once it comes in.
This is out of place, but this needs to be reiterated for newbs like myself... I never removed my engine cover before. It pulls off by lifting straight up. Watch for the 3 rubber inserts falling out of the grove... lift slow.
7tisix is offline
post #8 of 45 (permalink) Old 09-18-2010, 10:23 PM
Wow, that's a great price for the coil--where did you order from? Glad to hear you got it sorted out. I've pulled my engine cover a few times just to clean it. Pops off and back on quite easily.
JuneBug is offline
post #9 of 45 (permalink) Old 09-22-2010, 10:06 PM Thread Starter
Edit: This part failed!!!!
http://www.autopartswarehouse.com/
The coil was too tight a fit, so i had to file down the plastic a bit. It seems to be fine though. I went for a test drive and no check engine light. I'll post after a good break in.
7tisix is offline
post #10 of 45 (permalink) Old 09-23-2010, 08:35 PM Thread Starter
So far so good after 40 mile round trip.
7tisix is offline
