P0138 code problems - Toyota RAV4 Forums
post #1 of 34 (permalink) Old 01-26-2011, 09:43 AM Thread Starter
Country: wake_100's Flag is: United States
P0138 code problems
Okay... here is my issue. Check engine light came on, stopped at parts store, pulled the code. P0138 came up bank 1 sensor 2 high voltage. Replaced sensor, reset CPU, 40 minutes of driving later light came back on, stopped at parts store and the same code. No funny smell out of the exaust. any suggestions?
wake_100 is offline
post #2 of 34 (permalink) Old 01-26-2011, 10:35 AM
Rickl's Avatar
If the problem wasn't a bad sensor, it could be a problem in the wiring.
If you wanted to do your own work, have a look at this document for your 2AZ-FE ENGINE.
Link
It has a complete diagnostic procedure to help sectionalize the problem.
Rickl is offline
post #3 of 34 (permalink) Old 01-26-2011, 11:03 AM Thread Starter
Ive seen that document before but couldnt find it again... I have a service manual fot it but its not easy to find what your looking for in it. does the scan gauge II have the ability to monitor the voltages of the O2 sensors?
wake_100 is offline
post #4 of 34 (permalink) Old 01-26-2011, 12:14 PM
Rickl's Avatar
According to http://www.scangauge.com/support/pdfs/XGAUGE.pdf you can configure the XGAUGE feature to monitor the O2 sensor values.
I suppose that if you have a wiring problem, the O2 value for this sensor will remain at a constant value rather than constantly fluctuating as the ECM varies the A/F mixtures.
I was also wondering if the correct sensor was replaced. I once replaced the wrong O2 sensor in a Honda because I wasn't aware there were others on this particular model.
Rickl is offline
post #5 of 34 (permalink) Old 01-26-2011, 12:20 PM Thread Starter
you mean multiple sensors? with the 2.4 there is only 2 sensors. I checked the sensors for resisitance and they check okay as per service manual but we'll say something is on sensor one (upstream) that wouldnt change the value of the resistance I think. I think if sensor one was coated in soot it would make it rich making sensor two high voltage?
I am wondering about my vacuum system in it to. I can sit at a stop light, and just stretch my leg pressing the brake pedal and I can set of the stability control. it'll beep and the light of the car with skid marks under it will light up. can reproduce it 100%
wake_100 is offline
post #6 of 34 (permalink) Old 01-26-2011, 01:02 PM
Rickl's Avatar
Your O2 sensors are fed by two different circuits.
The first circuit is the heater circuit, and the other is the O2 detection circuit.
O2 sensors only work properly when they reach a certain temperature. In the old days they didn't work until the exhaust manifold was hot enough to provide the proper temperature. In today's cars they use heated sensors. The ECM provides a voltage solely to heat up the sensors to provide O2 data sooner than the old time technology. Faults with the heater circuit will normally give a different diagnostic code than the one you are getting.
The second circuit supplies battery voltage on one wire, and depending on what the O2 levels are, the sensor sends varying voltage back on a second wire. The code you are getting implies that this return voltage is higher than anything that should be normally seen. Therefore, either your sensor is defective, and is sending the battery voltage back on the signal wire, or a short somewhere in the harness is sending voltage back to the signal terminal of the ECM. The diagnostic charts in the PDF will help you determine where the problem is.
That is you HAC feature. Have a look at http://rav4world.com/forums/viewtopic.php?t=14769
Rickl is offline
post #7 of 34 (permalink) Old 01-26-2011, 01:04 PM
This is the hill−start assist control system, a feature, not a problem. Read the owner's manual.
JuneBug is offline
post #8 of 34 (permalink) Old 01-26-2011, 01:26 PM Thread Starter
how does the wiring all of a sudden go bad?
I am wondering about excess vibration since before I had this problem come up I had alot of snow in the wheels while i was driving down the highway.
wake_100 is offline
post #9 of 34 (permalink) Old 01-26-2011, 01:40 PM
Rickl's Avatar
There are many ways. The plastic dividers inside a connector may have broken which allows two wires to touch each other. The wiring harness touching a sharp piece of metal could cut through the insulation. A connector full of wet salt water would allow current flow between conductors.
Until you follow the procedure in the PDF file, you are just speculating that the problem is defective wiring.
Are you saying that you think the vibration caused your diagnostic code?
Rickl is offline
post #10 of 34 (permalink) Old 01-26-2011, 01:49 PM Thread Starter
Oh my phone is annoying me.
Right now I printed the guide and am reading through it. I can't look at the car I'd like to trade in right now as I'm at work.
I drove to my destination, parked it for a few hours, it was cold out maybe 7 degrees out. When I left about 20-30 minutes later the lights were on. It may be coincidence.
wake_100 is offline
