2007 Spark Plug Replacement - Toyota RAV4 Forums
post #1 of 13 (permalink) Old 10-13-2011, 06:31 PM Thread Starter
2007 RAV4 Sport 4 Cylinder
Can someone give me some idea of how difficult it is to replace the spark plugs in my vehicle? I would have a fairly experienced do-it-yourselfer helping me but he has never worked on a RAV4 before.
Platinum plugs seem to be cheaper but the manual says to use iridium. I would like to follow the manual's recommendation if it is reasonable - not just a way to get me to buy OEM plugs from Toyota.
mjhale is offline
post #2 of 13 (permalink) Old 10-13-2011, 06:43 PM
Country: Sr5Vr6Rav4's Flag is: United States
Sr5Vr6Rav4's Avatar
How to replace sparkplugs?
This is one topic that I have not seeing here yet. It would be nice to see someone post pics of spark plug replacement.
Sr5Vr6Rav4 is offline
post #3 of 13 (permalink) Old 10-13-2011, 10:11 PM
Country: Rav408's Flag is: United States
Rav408's Avatar
C'mon dude they are Super, duper easy on a 4cyl. Just take off the plastic cover, pull up the coils and unscrew the plugs. Then do the reverse. You should be done in 15 minutes if you take your own sweet time about it. The 6cyl on the other hand is a bit more trouble because of the front wheel drive design and the intake covering the rear plugs. You don't have to worry about any of that though.
Rav408 is offline
The Following User Says Thank You to Rav408 For This Useful Post:
bruins1 (10-04-2014)
post #4 of 13 (permalink) Old 10-14-2011, 05:57 AM
I don't have the 4 cyl RAV4, but here is a thread for a Tundra/Sequoia that should help you get started.
Spark Plug replacement HOW-TO w/ pictures
If you buy NGK plugs, you won't have to use anti-seize. Make sure the iridium plugs are pre-gapped correctly before you buy them at the store. Your owners manual should give you the proper gap and torque settings. If you try to gap them yourself when you get home, you may damage the iridium tip.
I like the magnetic spark plug socket over the rubber insert type. Make sure that you use electrical tape to keep the 6" extension attached to the socket. You don't want to leave the socket down in the hole when you try to remove it when you're done!
Good luck, take your time, and have fun. It's really not very difficult, unless you make it be.
INDYMAC is offline
post #5 of 13 (permalink) Old 10-14-2011, 07:06 AM
First off the iridium plugs last in excess of 100,000 miles so are you sure they need replacing? If so, using anything other than the correct iridium plug would be a foolish mistake. If you can unscrew a light bulb you can change the spark plugs.
2008 Base V-6
2008 Limited V-6
RTexasF is offline
The Following User Says Thank You to RTexasF For This Useful Post:
post #6 of 13 (permalink) Old 10-14-2011, 07:52 AM
How many miles to you have on your 2007 RAV4 Sport 4 Cylinder?
vanib is offline
post #7 of 13 (permalink) Old 10-14-2011, 10:52 AM
Rav408's Avatar
I have had that happen to me countless times. What I do is just insert a set of long needle nose pliers and pull the socket back out. Not a big deal really.
Rav408 is offline
post #8 of 13 (permalink) Old 10-14-2011, 01:08 PM
WJBertrand's Avatar
The only area of caution that I would advise is to use a torque wrench to install the new plugs into the head, which is aluminum. I've seen newbies bear down too hard and strip out the spark plug hole threads. You have to be pretty brutal to cause this to happen. If it does happen though, you have a world of hurt.
Spark Plug Installation Instructions
WJBertrand
2011 Rav4
WJBertrand is offline
post #9 of 13 (permalink) Old 10-14-2011, 01:18 PM
Country: ravrunner's Flag is: United States
ravrunner's Avatar
plugs
Rav408 is right easy job. just take your time Buy the iridium plugs because the the load they put on your coils are low.replaced mine at 70,000 miles and they looked good . I think at 120,000 they would have been fine.platnums would work but your coils could fail one by one and they are not cheap.
ravrunner is offline
post #10 of 13 (permalink) Old 10-14-2011, 02:37 PM
I have changed dozens of spark plugs without torque wrench, even on aluminum blocks. Just don't have to go crazy tight. All you need is the plug to be snug.
vanib is offline
