rear wheel abs sensor removal - Toyota RAV4 Forums
post #1 of 12 (permalink) Old 02-25-2012, 08:46 PM Thread Starter
Country: bspencer's Flag is: United States
I am wanting to pull the rear wheel abs sensor to clean it. Can someone tell me how to extract the sensor from the hub assembly. Does the round piece just pry out ,as it would just be a press fit holding it in? The front was quick and easy. Thanks
bspencer is offline
post #2 of 12 (permalink) Old 02-25-2012, 09:19 PM
I've removed my left rear sensor a couple of times. You have to work it out carefully and gently after removing the hold down bolt. Mine was pretty rusted in so some penetrating oil helped. Try twisting it a little.
Cleaning it last year reduced the frequency of the VSC/ABS/4WD/Brake lights coming on but I get a 34 code about any time I read it. So I just ordered a new one. $151.31 shipped from www.theautopartsshop.com
1968 Volvo 1800S
Dr. Dyno is offline
post #3 of 12 (permalink) Old 02-26-2012, 01:43 PM Thread Starter
I am looking at the right rear at this time and did not see a bolt other than what secures the wire to it . Am I missing something?
bspencer is offline
post #4 of 12 (permalink) Old 02-26-2012, 02:50 PM
Fred has the 4WD, which uses Rear Speed Sensor (for 4WD).
He does not have "Skid Control Sensor (for 2WD)"
See picture on BC-77 in http://share.qclt.com/%E4%B8%B0%E7%9...em/0370012.pdf It shows a bolt for the 4WD but not the 2WD.
Also see
http://share.qclt.com/%E4%B8%B0%E7%9...9/03700410.pdf
http://share.qclt.com/%E4%B8%B0%E7%9...29/0370048.pdf
I suggest you download the 2006 Service Manual, and check the BC (Brake Control) section. Then you can get those pages and more.
Carbon is offline
post #5 of 12 (permalink) Old 02-26-2012, 03:29 PM Thread Starter
Carbon, thanks for the references , I was hoping not to have to completely disassemble the hob to access the sensor. Think I am going to try a couple other things before doing that. Thanks again bspencer
bspencer is offline
post #6 of 12 (permalink) Old 02-26-2012, 09:07 PM
bspence,
If you have 2WD you need to replace the whole vehicle not the sensor!
Dr. Dyno is offline
post #7 of 12 (permalink) Old 10-09-2012, 07:10 AM
Country: crisko's Flag is: Canada
Curious if the 2006 Rav4 has a different wheel sensor than the ones described in the various "wheel sensor cleaning" sites? I've been having the famous 4 light ABS/Brake/VSC issue lately and the codes returned the right rear wheel speed sensor. I took the wheel off and removed the sensor this weekend (what a pain.. it was rusted in the hole) but the sensor itself is an enclosed black piece of plastic and was clean as a whistle. There was no metallic strip covered in dirt as described on the various posts, but rather a nice clean black sensor. Am I missing something here? What is there to clean off?
crisko is offline
post #8 of 12 (permalink) Old 03-05-2013, 11:02 AM
Country: JerD's Flag is: United States
How did you actually remove the sensor? Were you able to get it without removing the hub assembly?
JerD is offline
post #9 of 12 (permalink) Old 03-05-2013, 11:26 AM
Inspect this area. Rear ABS cable vulnerability
Carbon is offline
post #10 of 12 (permalink) Old 04-29-2013, 07:36 PM
Country: boschuster's Flag is: United States
So, can anyone tell me if the rear speed sensor just gets pulled out? As crisko semi-stated above... 2006 RAV4 codes tell me the right rear sensor has foreign object attached to end of sensor. Code 38. I cannot find a definitive answer for this question. I don't want to brake it!
boschuster is offline
