#31 (permalink) |
Country: Join Date: Aug 2007
Does anyone have pictures of the exact spots I can use? I don't have a hitch, need to lift the rear for various projects, but am seeing too much conflicting info
General G-MAX AS-03 235/55R18 summer tires Nokian Hakkapeliitta SUV5 225/70R16 snow tires SoundFX antenna Husky floor liners CompuStar Pro P2W9000FM-AS Canister shield OEM mud flaps Bluetooth OBDII+Torque Griffin BlueTrip AUX + Pocket Amp 2 BlackVue DR400G-HD DVR + Power Magic Pro |
#32 (permalink) |
Country: Join Date: Jan 2009
"Positioning a floor jack" is an item in the table of contents of your Owner's Manual. It is page 350 in mine.
2009 V6 4wd Base |
#33 (permalink) | |
#34 (permalink) |
Country: Join Date: Aug 2012
My factory hitch receiver blocks the jack point. There is a large flat square area on hitch receiver. I am concerned that it may slide off the floor jack because there are no groovesImageUploadedByAutoguide1353185792.709499.jpg
You can see it in the center of the picture Sent from my iPhone using AutoGuide.com App |
#35 (permalink) |
Country: Join Date: Jul 2005
To the OP, I asked a similar question in the spring....Alternate Jack Positions for the 4.3......as I don't like the factory ones. My small 2 ton jack won't reach the center front and center rear points, but even if it did...they look so flimsy....
Re the factory rocker panel positions, have you ever seen an older vehicle that has used these positions repeatedly.....they're all bent and rusted...at least in the snow belt they are.... For the rear: I used a piece of plywood about 1 foot sq. between my jack and the heavy rear control arm (for lack of the correct name). It only lifts one corner, but if changing tires, it only takes a few pumps to get the tire off the ground.... I'm still looking for some "good" alternate front positions..... My 4.1 and 4.2 were so much easier to lift.....
-Jim Red Gloves Rule _ 99 |
#36 (permalink) |
Country: Join Date: Mar 2012
I used the factory jack point this past weekend and it works just fine, I have a fairly large floor jack so I was able to get it high enough to put the car on stands using the side jack points
'08 Tundra SR5 5.7 2wd Super White/Black (mine) '10 RAV4 V6 2wd Blizzard Pearl/Bisque (hers) HID Projector Retrofit, EBC Green Stuff F&R, Goodyear Assurance ComforTread Extended Toyota family: '99/'12 Camry and '12 Camry Hybrid, '10 RAV4, '10 and '12 Prii, '08 IS350, '02 Avalon, '95 and '00 ES300 |
