Heater and air cond problem - Page 2 - Toyota RAV4 Forums
post #11 of 14 (permalink) Old 10-12-2012, 11:38 PM
Originally Posted by brianentz View Post
interesting. The one in back works fine. and the fuses look fine. Just a bad connection somewhere. I doubt its related to the air problems. just happened at the same time.
May be a coincidence but I'd try a male-to-male cable to power the mid outlet from the rear one. Would tell you if the bad connection has something to do with the climate control.
Dr. Dyno is online now
post #12 of 14 (permalink) Old 10-12-2012, 11:58 PM
It seems unlikely there is a connection (no pun intended). But if there is, that would probably be a ground problem. You could try measuring the voltage from the outer (ground) contact of the socket to some frame ground. While probing, check to see if the center conductor has voltage on it.
Carbon is offline
post #13 of 14 (permalink) Old 10-13-2012, 12:20 AM
Agreed. First verify that it's a loss of 12V at the center of the socket not a fault on the ground side.
post #14 of 14 (permalink) Old 12-10-2012, 09:28 AM
Fox
Country: Fox's Flag is: United States
Brianentz-
Wondering if you ever found out what was wrong? Mine heater was doing the same thing this morning, it's too cold for that here in Michigan!!!!
Thanks,
Fox
Fox is offline
