Country: Join Date: Jul 2012
So the heater is out completely (getting awfully chilly out). It does not a thing. The air conditioner only starts once the vehicle has started moving. Once moving it's fine. Still, I imagine there is some sort of electrical connection. The fuses look fine. But I can't get good electrical info. Is there a relay switch that might be bad. Also, one of the cig lighters is out - but that's probably unrelated. It's a 2006 rav4.
HELP!? |
Country: Join Date: Aug 2007
It would help to know which model of RAV4 you have. Is it a Limited with the automatic system, or one of the other models with a manual system?
Are you saying that the blower runs at all the various speeds, but doesn't blow heated air?. Are you saying that when AC is selected, the blower also runs at the various speeds but only seems to blow really cold air once you are moving.? Can you successfully direct the air out of the various vents like windshield, floor, and upper dash vents when you select them with the controls. Which of the three cigar lighters is not working? Have you checked all three?
it's an automatic.
the blower runs but the heater doesn't heat the air. Just a fan. However, the problem with the air is that the blower doesn't come on (heater or air conditioner) till the car is in gear and starts to roll. Then the air conditioner is fine, but the heater never warms up. |
Country: Join Date: Jan 2010
To be sure, is your RAV4 a Limited with sunroof and climate control like mine?
#5 (permalink) | ||
But your ventilation system is manual if you have the base model. Only the limited models have automatic systems. Quote:
When you come to a stop does the fan stop working again? Does the the fan change speeds as you change them with the controls? Can you direct the air to the various outlets such as windshield, floor, and face vents? How about more information on which of the three cigar outlets is not working?
Thanks Rick, I finally found it under "About Me" probably the last place I'd think to look. I like to be helpful but sure wish people would put the info in their signature. The more I have to hunt the less likely I am to respond.
There's an active post now called "HELP." Anyway, we need answers to your questions on this one.
Fred __________________ 2006 RAV4 V6 4WD Red Limited 2006 Accord V6 Hybrid - quick as the RAV but +8 mpg 1999 F-250 4X4 Diesel - snow plow, Bully Dog chip 2001 F-250 4X4 Diesel - truck camper, TS chip, 20' bike/trike dyno trailer 2004 Suzuki DRZ-400S Dual Sport It's the pedal (or the handgrip) on the right!! Last edited by Dr. Dyno; 10-12-2012 at 01:33 PM. |
It is an automatic. A limited with a sunroof. What I'm describing is a new development. The heater used to heat just fine. The blower used to start when the key turned and it would remember what the settings had been the time before. The first thing I noticed was no heat, then it stopped remembering the temperature and blower settings, then it started with the blower not starting till the car was rolling. Once the car is rolling it continues to work well until you turn the key off. Again, I'm describing a recent change. It used to operate quite differently.
The blower does run at all the speeds - just no heat at all. In fact the air conditioner blows at full cold and you can't adjust the temperature down if it gets too cold - you can only turn down the fan speed because the heater is doing nothing. Also, the cigarette lighter that went out was just the middle one under arm rest. Also, all the vents work fine. The blower works fine. There's only two air problems: no heat from the heater and the air conditioner only works once the car starts rolling. Oh, and it forgets the temp and fan speed settings every time and has to be reset manually. |
#9 (permalink) |
interesting. The one in back works fine. and the fuses look fine. Just a bad connection somewhere. I doubt its related to the air problems. just happened at the same time.
#10 (permalink) |
You might want to try the diagnostic procedure posted by our Humble Administrator (Junebug) in this post.
