#13 (permalink) |
Country: Join Date: Nov 2012
when car sits for a couple of days in humid weather, CEL, VSC and 4WD comes on. error code indicates bad ECM but that is misleading as the exact code has been debugged by someone's experiences on the internet as a bad O2 sensor, error goes away after one day. problem does not occur often which makes me confident the ECM should not be replaced for over $1000.
also symptoms are extremely poor MPG and car has 115K miles with original sensors. |
#14 (permalink) |
Country: Join Date: Feb 2012
Don't rely on a diagnosis with a single incident with the MIL light. If the light emits and a test of the OBDII indicates O2 sensor, try a oxygen safe carb cleaner in the throttle body, clean the TB and enough cleaner to smother the O2sensor(s). You just may buy some time and distance. But if your MPG is suffering you may have to bite the bullet. Getting at least 100,000 miles on a O2 sensor is good life, heated or not.
#15 (permalink) | |
I just don't want to overpay for replacing the sensors that's all. I want to get informed about what a realistic cost to do the job is so I don't get taken advantage of.
