cost to change O2 sensors - Toyota RAV4 Forums : RAV4World.com
Old 11-19-2012, 04:47 PM   #1 (permalink)
Country: techguy's Flag is: United States
Default cost to change O2 sensors
my local toyota dealer has quoted $621 to change the two O2 sensors in my 2006 I4 with 115K miles. an independent toyota repair shop quoted $500 with using Denso parts.
its my understanding is that its a 20 minute job per sensor so my question is how reasonable are these quotes and are there alternatives.
the CEL codes and symptoms indicate that changing the O2 sensors is the proper solution. I have not had either do in depth diagnostics at this time since the CEL code gives anyone an excuse to try and sell me a new ECM which is not really the issue per what I have read.
techguy is offline   Reply With Quote
Old 11-19-2012, 05:19 PM   #2 (permalink)
Country: drzsmum's Flag is: Canada
Check how much your cost would be for the Denso O2 sensors and figure out from that how reasonable it is for you. We all have different abilities and the value for someones labour can be different for everybody. Make sense?
Toyota Family x2
2007 Rav
2006 Tundra
drzsmum is offline   Reply With Quote
Old 11-19-2012, 05:25 PM   #3 (permalink)
I found one website that has the sensor with the proper harness so no soldering is needed. priced at $75 each.
I would like to understand if there is a valid reason to pay $350 to $450 for an hour or two of work ?
I can't do it myself
Old 11-19-2012, 06:30 PM   #4 (permalink)
WJBertrand's Avatar
Sounds high to me. Figure the shop would pay similar to your price for the parts and then probably double that for their mark up, so $300 parts and < 1hour to replace both at about $80/hr. I wouldn't think you should pay more than $400 for the job.
I replaced one on my Lexus for $75 (Amazon - OEM ND even) and about 15 minutes labor.
If you can't do it yourself do you have a handy fiend that might do it for some pizza and beer?
WJBertrand
2011 Rav4
Old 11-19-2012, 06:44 PM   #5 (permalink)
That does seem high, but sometimes they can be a real bugger to get out. Some places will install the parts if you supply them. Might save a few bucks this way if you look into it.
Toyota Family x2
2007 Rav
2006 Tundra
Old 11-19-2012, 06:49 PM   #6 (permalink)
Country: studiculous's Flag is: United States
studiculous's Avatar
Just had the front sensor changed on my 2006 I4 (109,000 mi) for $200 (Toyota Part) + $34 labor at my regular private garage. The front is pricey as it has a heater as part of the sensor core. I have seen the Toyota sensor on line for that price. Most blogs will tell you to stay OEM on Toyotas as they don't like Walker or Bosch. Shop around for a better price.
2006 Base I4 4WD
Wade deflector and visors, Weathertech floor liners, AntennaX 13" Euro, Sendel S06 chrome rims with NOKIAN WR G2 all weather tyres, Powerstop rotors and pads
You can't fix stupid
studiculous is offline   Reply With Quote
Old 11-19-2012, 07:47 PM   #7 (permalink)
Send a message via AIM to ronbo1313 Send a message via MSN to ronbo1313 Send a message via Yahoo to ronbo1313
I got the same pricey OEM DENSO sensor for my 2004 on ebay $85 deliveried to my door. Installed myself.
ronbo1313 is offline   Reply With Quote
Old 11-19-2012, 08:17 PM   #8 (permalink)
Shep426's Avatar
I have to ask this what is wrong with the old ones, CEL on ?
Old 11-20-2012, 05:35 AM   #9 (permalink)
If the front sensor is bad, it shuts off VSC and 4WD.
2006 Base I4 4WD
Old 11-20-2012, 11:27 AM   #10 (permalink)
WJBertrand's Avatar
Not sure but I think all the sensors are heated. Anyway I found the OEM ND ~$79.00) one was actually cheaper than the Bosch replacement ~$100) on Amazon.
I wasn't too concerned about making sure I used the OEM sensor, just that it was cheaper was the main reason I used it. I replaced a bad OEM ND with Bosch in my Toyota Sienna and it worked just fine in there for more than 100,000 miles!
WJBertrand
2011 Rav4
