Oil Life System - Toyota RAV4 Forums : RAV4World.com
Old 01-16-2013, 01:31 PM   #1 (permalink)
Country: Songdog's Flag is: United States
Default Oil Life System
Does the oil life system on a 2010 Rav4 monitor the engine oil life based on driving speeds, rpm, etc. or does it monitor only the miles driven since the last reset of the system? I've searched for an answer but can not find one.
2010 Rav4 Base 6cyl 4WD w/ tow prep and hitch
2013 Highlander Limited
Songdog is offline   Reply With Quote
Old 01-16-2013, 03:09 PM   #2 (permalink)
WJBertrand's Avatar
My maintenance light comes on exactly 5000 miles after it was last reset. Doesn't matter how the car has been used.
WJBertrand
2011 Rav4
Old 01-16-2013, 04:50 PM   #3 (permalink)
OK. So it is really just a mileage checker and not an engine analyzer type system.
Old 01-16-2013, 05:49 PM   #4 (permalink)
You are correct. The 2010 RAV4 does not have an oil life monitor. It has a counter that goes off every 5K miles. On the new ones using 0W20 synthetic (change every 10K) it still goes off every 5,000 miles to remind you to rotate tires.
Old Bird......sometimes wise
Both with Tow Prep Package
Old 01-16-2013, 09:40 PM   #5 (permalink)
Country: rminor's Flag is: United States
What new one's are using synthetic oil? Last time I checked no Rav4's were on the list. In fact I emailed them asking why my V6 was not on the list even though other models with the same engine ('12 Camry I4 & V6) are on the list. I received this dumb reply " Your vehicle VIN ************** uses and is only designed for conventional oil and the replacement period is 5,000 miles or 6 months, whichever comes first. "
rminor is online now   Reply With Quote
Old 01-17-2013, 04:48 PM   #6 (permalink)
Four cylinder models not V-6. I believe the longer interval started in 2010 when 0W20 synth was specified. Sorry, I should have been specific. V-6 in the RAV has always been 5W30.
Old 01-17-2013, 05:31 PM   #7 (permalink)
I just went back to that Toyota web page that lists the models that can use synthetic and no Rav4 models are on it. Toyota Synthetic Motor Oil Change and Replacement Services and Information
Old 01-17-2013, 07:24 PM   #8 (permalink)
Country: mrodgers's Flag is: United States
I just googled synthetic oil in Rav4 V6. What I am reading is it is ok to use synthetic oil at the recommended weight, it is just not listed as recommended for 10,000 mile oil changes? Would that be a correct thought?
I use Mobil1 synthetic in all my vehicles. I would want to continue that with my new Rav4 if/when I get it. If it is not recommended because of the 10,000 mile extended change interval, then I would change it at the 5000 mile interval for warranty. That would be OK, correct? I don't see what would make a difference whether it is regular oil or synthetic as long as you stick with the recommended change interval according to a warranty.
After the warranty though, I would switch to changing the Mobil1 synthetic every 7500 miles as I have been with every car I've owned for years and years.
mrodgers is offline   Reply With Quote
Old 01-17-2013, 07:45 PM   #9 (permalink)
That's what I'd do, especially with the type of highway driving you mentioned on your other thread.
Old 01-17-2013, 08:21 PM   #10 (permalink)
You're taking a BIG chance since your car is "designed for conventional oil only" per Toyota.
