Country: Join Date: Jan 2013
Hello,
I'm having trouble getting my 06 Rav4 to start I was involve in an accident and I hit the fuse box (driver side) and the cables to the battery were cut off by my mechanic and doesn't know where the heck to connect the wires to.... this is one of the wires (green arrow) we don't know where it goes connect it to.....This wire is white with some blue on it we've looked through underneath the fuse box to find the same color cable but i cant seem to find the same wire with the color ![]() other images of the my rav4 with the wiring mess he created... ![]() ![]() ![]() ![]() please help get my SUV started again....all feed back would be appreciated Thanks in advance. regards |
Country: Join Date: Jan 2009
. I am now thinking it is the power for everything except the starter. It either goes to the main fusible link, or that stub is part of the fusible link. In Junebug's profile, find the info on how you can download the electrical diagrams.
I have a red wire added visible in Annotated Pictures / Help with locating parts on 2GR-FE (V-6) engine but unfortunately the plastic cover hides the details. I am guessing I will also have a black wire too. Its too cold to check comfortably right now, but maybe somebody else will take a look.
2009 V6 4wd Base |
Country: Join Date: Nov 2008
I think Carbon is correct. Nice and sunny outside, 62F, so I went out and took a couple of pics. The cable in question runs behind the battery, then down and enters the fuse box from below. Just follow the red arrows:
i went to the dealer and looked at a rav4 there and seen the same wiring you posted here.....I dismantled the fuse box where that cable goes to but there is no torn white/blue positive cable that goes into the fuse box...
Look for a crimped connector that the wire may have been pulled from. According to the schematics, that wire goes through a fusible link and then to the fusebox where it is connected to the 80A main fuse, 120/140A alternator fuse, etc.
#6 (permalink) | |
Do you know where exactly the positive cable goes into the fuse box? Fuse number location? |
#7 (permalink) | |
#8 (permalink) |
The positive terminal wire should have the fusible link in line... like part of the wire.
In the diagram that Junebug posted, see terminal 1 of fuses 1,2,3,4 and some others... there is a line shown on the diagram connecting those terminal 1s. That probably represents some kind of a bus under the fuses. Look for a big black wire connected to that bus. That should be the non-battery end of the fusible link.
2009 V6 4wd Base |
| The Following User Says Thank You to Carbon For This Useful Post: | batis (01-25-2013) |
#9 (permalink) | |
pics of my fuse box and diagram of my Rav4 ![]() ![]() ![]()
#10 (permalink) |
It looks like you're missing a couple of relays--the fuel pump relay and the MG CLT relay which controls the A/C compressor. They are located just below the upside down "C". Also, there is a white connector at the bottom missing.
Here's a picture of my fusebox. Just remember, mine is a V6 with tow prep, so it may be a little different:
