Country: Join Date: Nov 2012
Hi,
I'm just about to attempt the first oil change on my 3.5 V6 Rav4. I've read through the how-to guide on the forums here (cheers to the bloke who did it makes a difficult job seem do-able). normally when I do a filter change with a spin-on filter I've always been taught to 1/3 to 1/2 fill the filter w/ fresh oil to help with oil pressurisation on the first start after the change. Now, I just wanted to double check that this is still the go with this new(er) type of filter. Is it still possible to "pre-load" the filter cartridge with oil? Cheers, TC |
Country: Join Date: Jan 2010
Yes, definitely. And I fill vertically mounted filters full not just 1/3 or 1/2.
Country: Join Date: Mar 2011
You may want to reinstall the canister drain bolt first before pre-filling the canister. Sometimes oil will seep out of the canister one way valve if the drain bolt is not installed. You can reinstall the drain bolt with the canister in your hand. Only 10 ft-lbs of torque is required. Make sure and use the new canister drain bolt O-ring supplied with the new filter. If you don't pre-drain the old oil out of the canister before removal, then this is a moot point.
Country: Join Date: May 2009
Although there's no necessity to do so, I was taught to pre-fill filters where possible, so I always have. If you don't do it, no harm done as there is still oil on all the moving parts. After all, you did warm the motor up to normal operating temp before changing, right?????
It's actually my sister's, but I'm the family wrench. |
Country: Join Date: Feb 2012
. . .is just like the one on my first car, a 1968 Mercedes Benz 220 Diesel!
"Don't tell me I'm in denial because I'm not!" 2008 Limited FWD V6 Pacific Blue Last edited by Scout706; 02-17-2013 at 10:12 PM. Reason: typso |
