Key Fob Battery Replacement Did Not Work... - Toyota RAV4 Forums
post #1 of 7 (permalink) Old 03-26-2019, 07:02 PM Thread Starter
Country: 2015RAV4LEAWD's Flag is: United States
2015RAV4LEAWD's Avatar
Quoted: 8 Post(s)
Question Key Fob Battery Replacement Did Not Work...
Am I missing anything... did some internet searches as well as searching the forums...
My key fob died, so I assumed it was the battery. I took it apart and ordered a new battery (was going to be out of town). Put in the new battery when I got back and the key fob is not working any longer. I tried a second battery, same result. Our spare key is working just fine.
Is there anything besides a dead key-fob that it could be?
We have the 3-button key for our 2015 LE
2015 RAV4 LE AWD
2015RAV4LEAWD is offline
post #2 of 7 (permalink) Old 03-26-2019, 07:52 PM
Quoted: 72 Post(s)
does the car still recognize it near Start push button without a battery?
2011 RAV4 V6 Limited
max5gen is offline
post #3 of 7 (permalink) Old 03-26-2019, 08:50 PM Thread Starter
Quoted: 8 Post(s)
This is the base model.
Still a turn key, no push button. The key still works fine, looks like the chip is RFID and separate from the lock/unlock buttons.
2015 RAV4 LE AWD
post #4 of 7 (permalink) Old 03-26-2019, 11:21 PM
Quoted: 72 Post(s)
You can swap batteries between remotes to determine the culprit. Make sure you inserting battery in the correct polarity.
max5gen is offline
post #5 of 7 (permalink) Old 04-18-2019, 10:22 PM Thread Starter
Quoted: 8 Post(s)
Finally got around to swapping the batteries between the two remotes... and it works fine in the other key... So I have a fob issue.
Will have to start looking into what it takes to change out the fob itself (inside the key).
2015 RAV4 LE AWD
post #6 of 7 (permalink) Old 04-19-2019, 09:18 PM
Quoted: 261 Post(s)
Most likely the transmitter part of the key is dead. Just so you know the transmitter is separate from transponder that allows the car to run. If you only have 1 working transmitter you'll have to have a dealer or locksmith replace the key.
Rav4system3 is offline
post #7 of 7 (permalink) Old 04-19-2019, 10:18 PM
Quoted: 209 Post(s)
Does the key start the car and just the lock/unlock buttons aren't working? You can buy a another keyfob from ebay and take the GUTS out and put it in the original keyfob. Then program it with techstream
https://www.rav4world.com/forums/96-...echstream.html
@2011rav4 is online now
Key fob battery Win262 4.4 Electric RAV4 Hybrid & EV 14 04-03-2019 12:02 PM
Adding an extra key using Techstream! JuneBug 4.3 General 231 12-27-2018 08:27 AM
Replacement Key fob.. Suggestions where to have the key cut.. macmanjimmy 4.3 General 9 10-03-2018 09:13 PM
Key fob issue (not battery) RPC207 4.3 General 0 07-02-2018 12:19 AM
Effects of Cross-Connecting Battery, or "Electricity: You're doing it wrong" mbrownatx 4.3 Mechanical 4 12-30-2016 08:20 PM
