Very strange, when turning... - Toyota RAV4 Forums
post #1 of 6 (permalink) Old 04-28-2019, 10:20 AM Thread Starter
Country: BoomerNJ's Flag is: United States
Quoted: 6 Post(s)
OK, this is going to sound very strange, but here we go... I'll be driving, going around a bend, jug-handle, something of the like...I'll take the turn/bend, and all of a sudden...the interior/dome lights go on (as if I opened the door), and the door-beeps go off (as if I opened the door). It's happened on a straight-away, but most times, around a bend/turn.
It happens for a couple of second at the most...but it's very strange...as if I opened the door and immediately closed it. I've checked the door, at least to the extent I can, and all seems to be sound, stable, etc. The doors close and function properly.
Any ideas? Thank you in advance.
BoomerNJ is offline
post #2 of 6 (permalink) Old 04-28-2019, 03:52 PM
Quoted: 261 Post(s)
What year car? On my 16 there is a graphic that shows which door is open. Figure out which door is the culprit. Once you do that you can adjust the door striker. This is what determines how far the door closes. It's possible your striker is loose and allowing the door to trip the open indicator. Could also be a wiring issue, but it will still tell you what door is the problem.
Rav4system3 is offline
post #3 of 6 (permalink) Old 04-28-2019, 04:10 PM Thread Starter
Quoted: 6 Post(s)
I've got a 2013 AWD Limited...it was the top of the line when I got it.
So, I don't have that graphic. I just get the repeating beep when a door is open. I guess I could check the striker. It happens once every few weeks. I hope it's that an not a wiring issue (as wiring sounds a lot more complicated...and expensive! LOL).
I'm lucky I can start the car, so I'll have to ask the mechanic. I'm bringing it in this week for an oil change.
Thank you for the insight.
BoomerNJ is offline
post #4 of 6 (permalink) Old 04-28-2019, 05:43 PM
Quoted: 261 Post(s)
You could start the car and from the inside try pushing each door open. If a striker is loose that door will move enough to trigger the alert.
The Following User Says Thank You to Rav4system3 For This Useful Post:
BoomerNJ (04-28-2019)
post #5 of 6 (permalink) Old 04-28-2019, 11:56 PM
Country: Foryota's Flag is: Canada
Foryota's Avatar
Quoted: 84 Post(s)
Does it happen turning left and right? Itís possible that itís on the outside of the turn (turning left would be right side). Might be a way to start investigating.
Current Fleet (of 2)
2012 RAV4 2.5 2WD Base
2017 Golf TSi Auto
Easy now, it's actually our 3rd Toyota!
Foryota is offline
post #6 of 6 (permalink) Old 04-29-2019, 08:52 AM
Country: Tom_B's Flag is: United States
Quoted: 2 Post(s)
Same thing happened on my 2006 Acura TL. The door striker slipped a bit so that the door was not 100% closed. When I rounded a curve, the door was forced outward and the lights and warning came on. I previously noticed that the door was not flush with the other body panels - another clue that the striker slipped a bit. I moved the striker back and tightened it up and it never happened again. BTW - when I pointed out the misaligned door to the dealer during a routine service visit, the service manager told me that the doors were aligned at the factory and there was nothing they could do!
Five mintes with a screwdriver would have fixed it.
Tom_B is offline
The Following User Says Thank You to Tom_B For This Useful Post:
dehill (05-12-2019)
shudder when turning austin 4.1 Faults & Fixes 3 04-28-2019 10:43 PM
1997 Rav4 H-LP Relay Strange Buzzing & Humming Sound skibum1 4.1 Faults & Fixes 2 02-12-2019 07:07 PM
Screeching While Turning - 2007 Rav4 Limited david5292 4.3 Mechanical 6 09-27-2018 11:16 AM
DIY: Easy fix for "popping" or "knocking" sound when turning demoder 4.1 Faults & Fixes 1 03-28-2018 02:22 AM
Urgent: Strange Noise from the back of the Engine Black-Phoenix 4.3 Mechanical 5 07-10-2017 02:59 PM
