Rear Wiper 10" or 12"? - Page 3 - Toyota RAV4 Forums
Old 02-22-2019, 10:20 AM
Country: svenster's Flag is: United States
svenster's Avatar
Quoted: 8 Post(s)
Originally Posted by CB91710 View Post
The OEM assembly is not designed to allow replacement of the blade itself. There are tabs on both ends and nothing for a refill to clip to.
I can't vouch for the quality of this specific bladse, but this is the type of blade needed:
https://smile.amazon.com/AUTOHAUX-Wi...s%2A=0&ie=UTF8
Ive had no problem using refills from the parts counter at Toyota. 9 bucks each.
2018 Toyota RAV4 XLE
svenster is offline
Old 03-13-2019, 05:58 PM
Country: whipaway's Flag is: United States
Quoted: 105 Post(s)
According to the info that I found, the EV uses 12" all others use 10"
Trico makes the Exactfit 10A, which would be the whole replacement assy.
https://www.ebay.com/itm/Windshield-...53.m1438.l2649
2013 LE AWD
1987 200SX SE-V6
whipaway is offline
Old 03-14-2019, 03:30 PM
CB91710's Avatar
Quoted: 394 Post(s)
That would make sense, since the EV was a carryover of the 4.3 body, and there are some structural differences between the 4.3 and 4.4, despite similar body lines/size and side windows.
-- Rich
CB91710 is online now
Old Yesterday, 04:54 PM
Country: 2015--rav4's Flag is: United States
Quoted: 2 Post(s)
I am looking for instructions on how to remove the entire " Arm " from the Liftgate wiper assembly...also has anyone tried cutting a 20" " Generic REFILL " in half ( using a Dremel type tool ) and using for a 10" refill ? thanks
2015--rav4 is offline
Old Today, 02:17 PM
CB91710's Avatar
Quoted: 394 Post(s)
There is a cover over the pivot that hinges up and away from the arm. That allows you to hinge the arm away from the window to provide access to replace the wiper.
I see others have commented that they were able to replace only the refill, but on my '15, both ends have a plastic tab that prevent removal of the blade without bending the snot out of it... meaning the replacement would be similarly bent to install.
Cutting a 20" down may be successful if you can get the old one out and the new one in without bending it up, though I would just use tin snips since the Dremel will burn through the rubber.
-- Rich
