Issues post TSB Torque Converter swap? Specifically leaks? - Toyota RAV4 Forums
post #1 of 4 (permalink) Old 04-30-2019, 02:50 PM Thread Starter
Country: adrenalinemedic's Flag is: United States
adrenalinemedic's Avatar
Quoted: 0 Post(s)
Thanks to the super helpful thread covering the TSB (I never got the letter), I had the torque converter in my 2013 replaced in February at 109k miles. This TSB saved me about $4100 at my dealership, and the shudder is gone (though there still is a noticeable vibration in the same RPM/speed range).
I went in a week ago to get the alignment checked and was told that both the rear main seal is leaking, and that the valve cover gasket is seeping, and they're going to be about $3800 to fix. They're denying that replacing the torque converter could have had anything to do with it, but when I had taken it in for scheduled maintenance in December, there were no leaks anywhere.
I tried combing through the FSM for the protocol to replace a torque converter, but I'm a medic not a mechanic, and couldn't make heads nor tails. I've also tried searching this site and Google in general to find out if replacing the torque converter has anything to do with the rear main seal. Of course the dealership says no, but what dealership goes out of their way to eat thousands of dollars in repairs?
Can anyone shed some light on this? I don't have a problem paying if its not related, but it's too much of a coincidence to not look into.
2013 XLE AWD
adrenalinemedic is offline
post #2 of 4 (permalink) Old 05-01-2019, 03:28 PM
arf
Quoted: 69 Post(s)
I had my TC done around 10 months ago.
No leaks at all for the time being. Keep us posted.
arf is online now
post #3 of 4 (permalink) Old 05-03-2019, 06:51 PM
Country: whipaway's Flag is: United States
Quoted: 109 Post(s)
The rear main seal is located between the engine and transmission just behind the flywheel. It is possible that an inept, inexperienced "mechanic" somehow damaged the seal during torque converter removal/replacement.
2013 LE AWD
1987 200SX SE-V6
whipaway is online now
post #4 of 4 (permalink) Old 05-04-2019, 01:25 PM
KTooTall's Avatar
Quoted: 32 Post(s)
No you don't remove the flex plate for TC replacement and the seal rides on the crank shaft, so even if the flex plate was removed the technician wouldn't have touched the seal. A TC replacement wouldn't cause a rear main seal leak.
KTooTall is offline
2013 RAV4 - Looking for Torque Converter TSB tron 4.4 Mechanical 8 11-16-2018 06:18 PM
DIY: Replace 4.2 Catalytic Converter, or A/F, Oxygen Sensors demoder 4.2 Faults & Fixes 9 10-15-2018 07:34 PM
Torque Converter Shudder, Trade it or Drive to Point of Failure? BBlueRav4 4.3 Mechanical 31 03-13-2018 03:25 PM
