Tow hitch - Page 2 - Toyota RAV4 Forums
4.5 Exterior Tires, Wheels, Lights, Spoilers, Flares, Bars, Tow Hitches, etc.
post #11 of 33 (permalink) Old 03-08-2019, 02:49 AM
Country: Diva459's Flag is: United States
Diva459's Avatar
Quoted: 2 Post(s)
I just purchased through Uhaul today. Literally they just came out two days ago. Just enter in your vehicle info on the uhaul website and it will pop up. Takes longer because it is still a custom build but mine will arrive in 4 weeks. Stoked!!!
Diva459 is offline
post #12 of 33 (permalink) Old 03-08-2019, 11:17 AM
Quoted: 2 Post(s)
$254 CAD with install. Thank for the tip. They're currently booking 1 month out.
For comparison an ecohitch is $790 installed in Canada.
You'll have to share some pictures when done. Curious if it's more visible than the ecohitch or the same asthetics.
hardoso is offline
post #13 of 33 (permalink) Old 03-08-2019, 11:35 AM
Country: YodaFJRav4's Flag is: United States
YodaFJRav4's Avatar
Quoted: 30 Post(s)
This thread caught my eye since I'm going to be buying a non-Adventure Rav4. After reading here, do I understand correctly that Toyota is going to offer a towing package "kit" for the other models?
Aftermarket only would be OK too of course. I was also wondering how much weight I could pull safely with an XLE? Is 1,500lbs the limit? Even with trailer brake module? Or would engine/transmission cooling be the limiting factor?
YodaFJRav4 is offline
post #14 of 33 (permalink) Old 03-08-2019, 11:45 AM
Quickdtoo's Avatar
Quoted: 1025 Post(s)
Personally I'll wait for a Curt or Drawtite and install it myself. Uhaul in the US now lists the $180 Draw-tite 76201G for the '19 Rav4.
https://www.uhaul.com/Trailer-Hitches/
2019 XLE Premium AWD
Quickdtoo is online now
post #15 of 33 (permalink) Old 03-08-2019, 11:50 AM
Quickdtoo's Avatar
Only the Adventure is rated at 3500lbs, all other gas models are rated at 1500lbs, but IMO with the same upgrades, IE: higher capacity radiator, transmission and engine oil coolers, heavier rear springs or air lifts, other trims will work fine too, there's a 4.4 owner here that has upgraded his and tows way over the 1500lbs with no problems other than it's not the fastest tow rig.
post #16 of 33 (permalink) Old 03-14-2019, 08:54 PM
Quoted: 60 Post(s)
Trimming of bumper is NOT required to install torklift eco hitch! You can just press the hitch against the bumper and it is flexible enough to deform a bit (thanks toyota for cheap and thin plastic). It took me about 20-30 minutes and I have never done any of these things before. You have to slide out the rubber holding the exhuast pipes on both sides and in the center if you want some space to work. No need to remove bumper. I did it mostly by myself with some help at the lining the holes up and bolting stage.
2019 RAV4 ADVENTURE (AKA 2020 TRD)
dcmb2003 is offline
The Following 2 Users Say Thank You to dcmb2003 For This Useful Post:
Quickdtoo (03-14-2019), sixtynine (03-15-2019)
post #17 of 33 (permalink) Old 03-18-2019, 05:26 PM
Quoted: 3 Post(s)
Interested in if the trailer hitch will interfere with the kick feature. I don’t want to turn it off I want a hitch and the kick feature to work.
Chlupper is offline
post #18 of 33 (permalink) Old 03-18-2019, 05:32 PM
Quickdtoo's Avatar
Originally Posted by Chlupper View Post
Interested in if the trailer hitch will interfere with the kick feature. I donít want to turn it off I want a hitch and the kick feature to work.
Ya can't have both, the only possible option is to relocate the kick sensor so the hitch doesn't block it, and I have no idea if that's even possible, just speculation.
https://www.rav4world.com/forums/191...ml#post2667635
post #19 of 33 (permalink) Old 03-19-2019, 04:37 PM
Quoted: 3 Post(s)
I contacted drawtite and they said it shouldn’t interfere. See attached email6779F037-4285-4659-9D40-8042DB1B2453_1553027795229.png
Chlupper is offline
post #20 of 33 (permalink) Old 03-19-2019, 05:45 PM
Quickdtoo's Avatar
I'd check with etrailer, they're a lot more knowledgeable since they actually do installations, and they have a lot of experience with past models.
https://www.etrailer.com/p-76201.html#/
