Mud Guard front tire clearance? - Toyota RAV4 Forums
4.5 Exterior Tires, Wheels, Lights, Spoilers, Flares, Bars, Tow Hitches, etc.
post #1 of 7 (permalink) Old 05-14-2019, 09:02 PM Thread Starter
Country: Lindenwood's Flag is: United States
Lindenwood's Avatar
Quoted: 21 Post(s)
Howdy, friends. I am considering installing mud guards, but I also have larger tires on order that will already be cutting it close with front tire clearance. Could somebody post a close-ish pic of the front mud guard, with the steering wheel turned toward the side of the camera? For example, taking a picture of the back of the driver's side wheel well, the pic would need to have the steering wheel turned toward the driver's side. I just want to have a rough idea of how far the guards stick out relative to the front turning arc.
Thanks!
Lindenwood is offline
post #2 of 7 (permalink) Old 05-14-2019, 09:14 PM
PhenixFord's Avatar
Quoted: 87 Post(s)
I can get it for you tomorrow. I'm, cough cough, not at home right now.
PS: For what it's worth, the splash guard is pretty much flush with the well. And only sticks out from the body a little bit more than the rocker guards. I think that you would rub somewhere else before you would get into the splash guards.
[ATTACH][/ATTACH]
2019 Lunar Rock Adventure
PhenixFord is offline
post #3 of 7 (permalink) Old 05-14-2019, 09:51 PM Thread Starter
Lindenwood's Avatar
Quoted: 21 Post(s)
Ah, thanks!! Yeah by my measurements, at the closest my factory tires were about .7" from the back of the wheel well as the wheel swings rearward when turning, maybe 4" from the outer edge. Between the .45" larger tire radius, .7" greater tire width, and 1/4" lower offset, my new tires will be within about 0.25" from the back of the wheel well at the closest. So, I just wanted to have an idea where the mud guards mounted so I'd have a better idea of where any rubbing might occur .
I'll definitely be using this vehicle off road, but even just after rains there are splatters along my doors from the tires that I'd like to minimize.
post #4 of 7 (permalink) Old 05-14-2019, 10:05 PM
Country: YodaFJRav4's Flag is: United States
YodaFJRav4's Avatar
Quoted: 36 Post(s)
Tire size concerns me too. They're stock for now, but the ones I like would be the size of the stock tires on the Adventure. I know the Adventure sits higher, but according to my imprecise calculations the difference appears to be the same as the difference in tire circumference between the XLE 17"and Adventure 19" tires.
So, does anyone know if there is any difference in actual suspension height between models???
2019 Rav4 XLE AWD
YodaFJRav4 is offline
post #5 of 7 (permalink) Old 05-14-2019, 10:20 PM Thread Starter
Lindenwood's Avatar
Quoted: 21 Post(s)
The XL tires are 225/65R17, which are 28.5". The higher-trim 19s come with 235/55R19, which are 29.2". That extra ~.35" of radius (height) is likely the source of the small difference in factory ground clearance, rather than suspension differences. I have not seen any indication that the mud guards are different between trims, which leads me to believe that you should not have any issues with near-stock tire sizes with a near-stock wheel offset.
I am putting on 30.1" tires, however, which brings the tread about .5" or more closer to the rear of the wheel well.
post #6 of 7 (permalink) Old 05-15-2019, 10:44 PM
Country: XA50_Trail's Flag is: Canada
Quoted: 52 Post(s)
Thanks!
Here my Trail with the factory mudguards. Only a little bit of clearance.
XA50_Trail is offline
The Following User Says Thank You to XA50_Trail For This Useful Post:
Lindenwood (05-16-2019)
post #7 of 7 (permalink) Old 05-16-2019, 05:19 AM Thread Starter
Lindenwood's Avatar
Quoted: 21 Post(s)
Attachment 125933
Gotcha!
Yeah, by my math the larger tires will protrude up to 0.81" further rearward with the steering wheel turned. So, not sure I'll have much extra room at all!
Front bumper guard tow cover help Dror Hazan 4.3 Exterior 1 09-17-2018 12:26 AM
SE/Ltd/Platinum/Adventure, clearance to front strut, trailing arm prechierav 4.4 Exterior 5 09-15-2018 09:54 PM
front bumper guard - unknown chrome part ? raaaaraaaa 4.4 Exterior 2 05-16-2018 04:36 PM
Costco alloy wheels AlbertaRav 4.4 General 10 02-18-2018 09:21 AM
Sounds like a flat spot in my front right tire Axoman 4.3 Exterior 22 07-05-2016 02:03 PM
