Torque Specs - Toyota RAV4 Forums
post #1 of 5 (permalink) Old 05-01-2019, 04:31 PM Thread Starter
PhenixFord's Avatar
Quoted: 78 Post(s)
Torque Specs
Hey Guys.
I seen it posted on here somewhere. But just can't find it. Looking for the specs on the oil drain plug and filter. Anybody know what they are?
Thanks
2019 Lunar Rock Adventure
PhenixFord is offline
post #2 of 5 (permalink) Old 05-01-2019, 05:49 PM
Quickdtoo's Avatar
Quoted: 1035 Post(s)
18-20 ftlb according to this Camry tutorial for the A25A-FKS.
https://www.paulstravelpictures.com/...-Change-Guide/
2019 XLE Premium AWD
Quickdtoo is offline
PhenixFord (05-01-2019)
post #3 of 5 (permalink) Old 05-03-2019, 12:09 PM
SuperSaiyanRuby's Avatar
Quoted: 11 Post(s)
Never used torque specs on a plug or filter. I just use a wrench. When it’s tight then Give it a little bit more and done. Oil filter is always hand tight and then 1/4 -1/2 turn more.
SuperSaiyanRuby is offline
post #4 of 5 (permalink) Old 05-03-2019, 04:16 PM Thread Starter
PhenixFord's Avatar
Quoted: 78 Post(s)
Originally Posted by SuperSaiyanRuby View Post
Never used torque specs on a plug or filter. I just use a wrench. When its tight then Give it a little bit more and done. Oil filter is always hand tight and then 1/4 -1/2 turn more.
I always do my best when it comes to working on stuff. But, for some reason, I always find a way to screw things up. My father was the same way. So I guess I got it from him. Although, I am quite experienced at driving screwdrivers through filters. And installing thread chasers. I just don't like practicing those skills.
post #5 of 5 (permalink) Old 05-05-2019, 08:00 PM
Country: MatRAV4's Flag is: Canada
Quoted: 3 Post(s)
From TIS
(d) Install a new gasket to the oil pan drain plug.
(e) Install the oil pan drain plug.
Torque:
40 Nm {408 kgfcm, 30 ftlbf}
4. INSTALL OIL FILTER SUB-ASSEMBLY
(a) Check and clean the oil filter sub-assembly installation surface.
(b) Apply clean engine oil to the gasket of a new oil filter sub-assembly.
(c) Lightly screw the oil filter sub-assembly into place by hand. Tighten it until the gasket contacts the seat.
(d) Using SST, tighten the oil filter sub-assembly.
SST: 09228-06502
(1) Depending on the work space available, choose from the following:
If enough space is available, use a torque wrench to tighten the oil filter sub-assembly.
Torque:
17.5 Nm {178 kgfcm, 13 ftlbf}
If not enough space is available to use a torque wrench, tighten the oil filter sub-assembly 3/4 of a turn by hand or using a common wrench.
5. ADD ENGINE OIL
MatRAV4 is offline
2009 RAV4 Inner and outer Tie rods Torque Specs Requested jmald10 4.3 Mechanical 5 02-04-2019 09:51 PM
Torque Specs? Dynasty 4.3 Mechanical 5 04-09-2018 05:27 PM
2007 Front Strut Replacement Torque Specs?? TheRichMonster 4.3 Mechanical 4 06-22-2017 08:44 AM
1998 Rav4 Engine Torque specs? COYOTA 4.1 General 28 09-19-2016 10:22 AM
Front and rear brake torque specs nmcindoo 4.3 Mechanical 1 01-24-2016 09:27 PM
