How to access License Plate bulbs . . . - Toyota RAV4 Forums
post #1 of 9 (permalink) Old 04-06-2019, 06:36 PM Thread Starter
Country: RAV4forPBS's Flag is: United States
Quoted: 16 Post(s)
Hello -
Has anyone replaced the License Plate bulbs in a 2019 RAV4. It's not apparent to me how to access these. There is not an access panel on the inside of the lift gate as I've seen in several other posts and videos about earlier RAV4's. Thanks
RAV4forPBS is offline
post #2 of 9 (permalink) Old 04-06-2019, 07:10 PM
Quickdtoo's Avatar
Quoted: 1070 Post(s)
The panel has to be removed to access the plate light, the video in the post shows how to remove the panel.
https://www.rav4world.com/forums/191...ml#post2679767
2019 XLE Premium AWD
Quickdtoo is offline
jackie999 (04-06-2019)
post #3 of 9 (permalink) Old 04-06-2019, 07:32 PM Thread Starter
Quoted: 16 Post(s)
Outstanding, thanks that's a big help, I can do that. (Now I'm tempted to try the wrap too!)
Any guidance where I can look up part numbers for the various clips? I hate to start a job like this only to break a clip or two and have to get parts at that point.
post #4 of 9 (permalink) Old 04-06-2019, 07:43 PM
Quickdtoo's Avatar
I'd find the look-alike fastener/clip on the website below which includes the OEM part number then find the part on Amazon so you don't have to buy so many, or just go to your dealer parts dept and they can look it up and buy a couple from them, but they charge a premium for parts usually. I haven't seen any '19 OEM parts online sites yet, just accessories, some don't even have '18 parts listed yet!
https://www.clipsandfasteners.com/category-s/776.htm
post #5 of 9 (permalink) Old 04-08-2019, 10:32 AM
Colonel's Avatar
Quoted: 49 Post(s)
Oi yoy yoy....All the more reason to put in a long lasting LED in that assembly!
2013 Ford Fusion Titanium
Colonel is offline
post #6 of 9 (permalink) Old 04-14-2019, 07:17 PM
Country: rjventre's Flag is: United States
Quoted: 13 Post(s)
Aren't the license plate bulbs LED anyway? Why would you change them?
rjventre is offline
post #7 of 9 (permalink) Old 04-25-2019, 07:35 PM Thread Starter
Quoted: 16 Post(s)
They are in fact LED. I didn't know that at the time that I purchased a "Kit" of LED bulbs, which included what the seller identified as replacements for the license plate bulbs. Well, I thought, I've got these I may as well use them. After going through the process of dismantling the inside of the liftgate to access them, it seems that the bulbs aren't even replaceable. At least it appears to me that the gray housing with clear lens is sealed, and that the LED is a chip on a PCB inside of it. Perhaps they reasoned that since LED's have such long life that they would almost never require replacing. I took a couple of pictures of the housings which I'll try to attach.
File Type: jpg 2019 RAV4 License Plate Bulb Bottom View.jpg (154.5 KB, 9 views)
File Type: jpg 2019 RAV4 License Plate Bulb Side View.jpg (125.8 KB, 9 views)
2019 XLE Premium AWD, Lunar Rock with Nutmeg SofTex Interior.
The Following User Says Thank You to RAV4forPBS For This Useful Post:
Astrodoof (04-26-2019)
post #8 of 9 (permalink) Old 04-26-2019, 09:04 AM
Colonel's Avatar
Quoted: 49 Post(s)
Are those four "clip like" things on the edge melted to the dark gray base? So that whole assembly goes into a lens fitting?
Colonel is offline
post #9 of 9 (permalink) Old 04-26-2019, 08:43 PM Thread Starter
Quoted: 16 Post(s)
Each of the two License Plate light assemblies snaps into one of the two cutouts in the lift-gate. The following photos are all of the lamp assembly to the left (drivers side) of the license plate as viewed from the exterior. Here are a few more photos . . .
1. Exterior view of the left assembly as installed. That's the back-up camera just to the right of the lamp assembly. (I could only take this shot straight on because my lift-gate garnish is off being wrapped).
2. Exterior view of the cutout in the lift-gate when the assembly is removed.
With the interior lift-gate trim parts removed:
3. Rear view of the assembly with power cable connected.
4. Rear view of the assembly with power cable dis-connected.
5. Rear view of the cutout in the lift-gate when the assembly is removed.
And a few other views of the assembly when removed:
6. An end view of the assembly. Note the snapping tab on the end, there is one on each end to release the assembly from the cutout.
7. Rear view of the assembly (Yes, the "Toyota" and other characters on the back of the assembly are upside down when installed, at least on mine).
So, after all that I don't think anyone is likely to go through this unless the factory LED actually fails and the assembly needs to be replaced.
File Type: jpg License Plate Light Housing Inside View Installed Connected.jpg (94.8 KB, 4 views)
File Type: jpg License Plate Light Housing Inside View Installed Unplugged.jpg (157.3 KB, 5 views)
File Type: jpg Left License Plate Housing Opening from inside.jpg (116.5 KB, 4 views)
File Type: jpg License Plate Light Housing Rght End.jpg (78.0 KB, 5 views)
File Type: jpg License Plate Light Housing Rear View.jpg (233.8 KB, 5 views)
dcmb2003 (04-26-2019)
Freaking Insane Front License Plate platform!! thoots 4.5 Exterior 11 03-29-2019 09:47 AM
The mystery of the bent front license plate Flyover 4.3 Exterior 18 03-21-2019 11:40 PM
Better headlight bulbs? Inocense 4.3 Exterior 55 12-15-2018 11:34 AM
Front Tow hook license plate mount kevinw 4.4 Exterior 0 07-12-2018 04:53 PM
Canadian Man Forced to Surrender 'Offensive' Star Trek License Plate JuneBug Off Topic 7 05-03-2017 07:32 PM
