Problem to solve - overheating - Toyota RAV4 Forums
post #1 of 22 (permalink) Old 04-23-2019, 09:28 PM Thread Starter
Country: jamguy's Flag is: United States
Quoted: 3 Post(s)
Filled up my 97 Rav4 today at a Costco. Had no problem for the whole day but in the evening, the engine started misfiring suddenly. The "check engine" light did not come on but I noticed when I limped home that the engine was running hot (could hear the coolant boiling), but the gauge was reading normal. Will take it to my mechanic about 25 miles away. He's the only one that works on my car. Hopefully I wont shut off on the road and need a tow (not a crisis as I have AAA). The car is 10K miles short of a timing belt change, and the fan belt seems OK. Hope it is something that they can diagnose quickly so that my "baby" will be OK. Just hoping it's nothing serious. Thought I'd throw it out there for you guys to mull over. Will let you know the result.
jamguy is offline
The Following User Says Thank You to jamguy For This Useful Post:
Elle_Rav4 (04-24-2019)
post #2 of 22 (permalink) Old 04-23-2019, 11:00 PM
Quoted: 1214 Post(s)
DO NOT try to drive it since you'll likely ruin it if you haven't already. Have it towed. I'm quite sure your mechanic would agree.
1968 Volvo 1800S
Dr. Dyno is offline
post #3 of 22 (permalink) Old 04-24-2019, 01:29 AM
Quoted: 38 Post(s)
Listen to Dr Dyno, and have it towed!! Don't even take the chance.
Hopefully what you heard was air bubbles in the system. Hopefully the misfiring was just oil on the plugs, which is easily fixed by a spark plug tube re-seal. But if she really was overheating, then you could have some big issues, and you don't want to make anything worse by over-heating her again.
Overheat these little engines and you can very quickly be looking at a blown head gasket, which isn't the end of the world, but it gets very expensive very quickly.
Please let us know what your mechanic finds!
demoder is offline
The Following User Says Thank You to demoder For This Useful Post:
post #4 of 22 (permalink) Old 04-24-2019, 07:52 AM Thread Starter
Quoted: 3 Post(s)
I will. Hopefully it will be OK. Don't really want to buy a newer car as I like a manual transmission and they are almost impossible to find in any model I like.
jamguy is offline
post #5 of 22 (permalink) Old 04-24-2019, 11:21 AM
eodgator's Avatar
Quoted: 228 Post(s)
It sounds like the Engine Coolant Temperature Sensor (ECT) is going out.
Like humans, a vehicle needs to maintain a specific temperature in order to function properly. Too cold, and the vehicle will drink too much petrol. Too hot and the head gasket could leak. Coolant is a liquid used in the vehicles radiator of the car to maintain the temperature at which the engine can perform at its optimum.
The engine coolant temperature sensor simply tells the car's computer (ECM) the current temperature of the vehicle. When the temperature of the coolant reaches between 75 and 95 degrees (depending on the manufacturer specifications), the ECM instructs the radiator fan to turn on and start cooling down the liquid.
Usually it is located either on the bottom of the radiator, or by follow the top radiator hose towards the engine block. You'll see it on mounted on the engine block.
It can be cleaned using a wire brush when you entirely change your engine coolant (approx. every 80,000 km or 50,000 miles).
Symptoms of a Bad or Failing Coolant Temperature Switch (Sensor) Common signs include poor fuel economy, black smoke coming from the engine, engine overheating, and the Check Engine Light turning on. On the RAV4.1 it can prevent the engine from starting.
Easy fix and doesn't require a mechanic. You simply remove the old sensor and install the new one, It's even easy to get to.
See this link Engine Coolant Temperature Sensor Failure
eodgator is offline
post #6 of 22 (permalink) Old 04-24-2019, 01:48 PM Thread Starter
Quoted: 3 Post(s)
Thanks for all the advice. Turned out that the plugs, rotor cap, coils and wires needed to be replaced. Also replaced the Coolant Temperature Sensor as per Edogator's advice. I don't think the old one was working properly since the coolant level was low even in the absence of any leaks. The mechanic tested the sytem for leaks and found none. Took the opportunity to do an oil change too. So everything seems to be back on track, running great. I think there's a lot of life left in her!
jamguy is offline
The Following 2 Users Say Thank You to jamguy For This Useful Post:
Elle_Rav4 (04-24-2019), eodgator (04-24-2019)
post #7 of 22 (permalink) Old 04-24-2019, 03:12 PM
Country: LugNut's Flag is: United States
LugNut's Avatar
Quoted: 84 Post(s)
Check the cooling fan too, with the engine running. Test #1 : Activate the A/C, radiator fan should run on high. Test #2 : With the engine hot, the fan should either run continously or cycle on/off.
Also check the upstream side of the radiator/condensor for too many dead bugs, dustbunnies, etc.
If still a problem (hopefully already solved, but ...), water pump and thermostat would be next on my list. They should get done while doing the timing belt too.
LugNut
2000 RAV4.1 L, rare Special Edition w/ Leather, AWD
All stock except stereo system, subwoofer, dash cam,
turbo exhaust, outdoor air temp gauge, louder horns, extra ground wire
LugNut is offline
The Following User Says Thank You to LugNut For This Useful Post:
post #8 of 22 (permalink) Old 04-24-2019, 03:27 PM Thread Starter
Quoted: 3 Post(s)
The mechanic did the fan test you describe. When I get the timing belt replaced in another 8-10K miles (246K), I'll replace the other two items you mention at that time.
jamguy is offline
post #9 of 22 (permalink) Old 04-24-2019, 08:23 PM Thread Starter
Quoted: 3 Post(s)
I also repeated the fan test. I notice only one of the fans cycle on and off. Don't know if this is important but wil let the mechanic know. He advised me to watch the coolant level over the next few days to see if it changes. The funny thing is that the engine feels like it's running hot but the gauge is showing normal despite the fact that the ECT was changed.
jamguy is offline
post #10 of 22 (permalink) Old 04-24-2019, 10:17 PM
Elle_Rav4's Avatar
Quoted: 38 Post(s)
The ECT sends a signal to the engine computer that adjusts fuel ignition, timing, open loop and closed loop operation, et cetera. It does not cause the coolant temperature to change, at least not directly. Coolant temperature is for the thermostat and fan switch to control. The temperature gage reading on your instrument cluster gets its signal from the (one wire) water temperature sending (WTS) unit located right next to the (two wire) ECT sensor. See picture at http://hele.foute.info/rav4.1/ect.and.wts.jpeg . I would be surprised if the temperature gage was not reading correctly.
Here is the cooling fan circuit: https://www.rav4world.com/forums/mem...an-circuit.jpg . A description of how the circuit works follows. If the fans are switching on and off in a strange manner, from reading here I would wonder if the a/c pressure switch was on its last legs. If you can identify which fan seems to be cycling, this might be helpful.
From member Eodgator and the service manual:
LOW SPEED OPERATION
When the ignition switch is turned on and the a/c is activated, current flows from the mg/c relay (point side) -> the fan no. 3 Relay (coil side) -> GROUND, and the FAN no. 3 Relay is turned on. As a result, current from the CDS FAN fuse flows to terminal 2 of the a/c condenser fan motor -> terminal 1 -> the FAN no. 2 Relay (point side) -> the FAN no. 3 Relay (point side) -> terminal 2 of the radiator fan motor -> terminal 1 -> ground, and both of the fan motors, with the result that the fans are activated at low speed.
If the engine coolant temperature is approx. 90C (194F) or less, and the refrigerant pressure is approx. 15.5 Kg/cm2 (1323 kpa, 191.7 psi) or less, both the a/c water temp. Sw and the a/c single pressure sw are closed, so that the FAN no. 1 Relay and the FAN no. 2 Relay are turned on. As a result, both of the fan motor operate at low speed.
HIGH SPEED OPERATION
When, during a/c operation, the refrigerant pressure becomes higher than ordinary level (approx. 15.5 Kg/cm2 (1323 psi. 191.7 Kpa)), the a/c single pressure sw is turned off. As a result, the FAN no. 1 Relay and the FAN no. 2 Relay are turned off, and the current flows from the RDI FAN fuse to FAN no. 1 Relay (point side) -> terminal 2 of the radiator fan motor -> terminal 1 -> ground, and current from the CDS FAN fuse flows to terminal 2 of the a/c condenser fan motor -> terminal 1 -> the FAN no. 2 Relay (point side) -> ground, and to both of the fan motors in parallel, thus causing the fan motors to operate at high speed.
Note that, because the current flows in the same manner even if the coolant temperature is approx. 90C (194F) or higher, the fan motors still operate at high speed.
Elle_Rav4 is offline
Problem starting ladysilver 4.2 Faults & Fixes 2 03-05-2019 06:22 PM
AC Problem That Defies Logic ravgogo 4.3 Mechanical 11 08-13-2018 12:32 PM
Yet another overheating thread........ Sinner 4.1 Faults & Fixes 2 10-09-2017 10:48 AM
how to solve ABS, BRAKE, VSC light mara.chiamaia 4.3 Mechanical 3 05-14-2017 12:56 PM
Ignition barrel problem mudinuri 4.1 Faults & Fixes 5 11-15-2015 04:11 AM
