Back up Camera Wiring help!! - Page 3 - Toyota RAV4 Forums
4.2 Accessories Discuss RAV4.2 accessories, their installation, where to purchase, etc.
post #21 of 32 (permalink) Old 02-21-2016, 05:50 PM
Country: spacey's Flag is: United States
spacey's Avatar
Quoted: 27 Post(s)
I have the 4.3 rav4 2010, still same can wires from the car though.
Car black = camera red
Car red = camera black
Car white= camera yellow
Car (no color wire) = camera white
My car already had a backup installed cam so I just spliced into the large black wire under the passenger scuff plate. My head unit was also spliced in using the same camera color wires.
The wire connections are in the photo.
spacey is offline
post #22 of 32 (permalink) Old 07-05-2016, 11:27 AM
Quoted: 4 Post(s)
Can you help me with adding a a camera to a 2011 RAV$ limited. I see the space on the license plate to hold the camera, but no idea if the car is porewired for me or do I need to run the cables all the way to the front of the car. The image that you have attached...where is that location in the car?
dsat is offline
post #23 of 32 (permalink) Old 08-14-2016, 07:47 AM
Country: akohler's Flag is: United States
akohler's Avatar
Quoted: 8 Post(s)
Do you mean
Car Red = camera white
Car (no color wire) = camera black
I'm looking at the 4.3 Parking Assist wiring diagram, and the camera connector, connection Q13. Everything else matches up, except those two wires being transposed.
Shut your mouth or I'll shut it for you -- Mahatma Gandhi
akohler is offline
post #24 of 32 (permalink) Old 03-10-2017, 07:00 PM
Country: Rich D's Flag is: United States
Rich D's Avatar
Quoted: 6 Post(s)
thats fine IF you wanted to connect wire Up Front as indicated, But if you didn't want to run another wire to that , Since All the other wires are in the Back Rear Rt,
I Want to Make my Connection by the Rt Tail Light !
Is it Still a Red Wire at this Location ? or is it Yellow?
Rich D is offline
post #25 of 32 (permalink) Old 03-10-2017, 08:30 PM
Country: nouse4aname's Flag is: United States
nouse4aname's Avatar
Quoted: 210 Post(s)
Only wire that should run the length of the vehicle is the video cable. Power stays at the back and the signal goes to your head unit.
nouse4aname is offline
post #26 of 32 (permalink) Old 03-10-2017, 08:45 PM
Rich D's Avatar
Quoted: 6 Post(s)
Nouse4, Yes, thats what i did
& Understand that I need the Power Connection at the Back !
so which color wire at the back do i use for the BACK UP REVERSE for my Power Connection ??
Rich D is offline
post #27 of 32 (permalink) Old 03-10-2017, 09:41 PM
Quoted: 210 Post(s)
I tapped the power socket back there myself to have constant power so I can switch to it on demand rather than only in reverse. Recommend that if your head unit supports that feature.
post #28 of 32 (permalink) Old 05-27-2017, 02:28 PM
Quoted: 2 Post(s)
Where you connect the red wire in the dash for the reverse signal is there a 12volt positive and ground on that harness or around there to connect to? My mirror needs them and would be nice to keep all connections in that spot.
Dohcv6 is offline
post #29 of 32 (permalink) Old 05-27-2017, 07:59 PM
Quoted: 2 Post(s)
I hooked ground to a spot next to the door and 12volt switch to this white wire. Only thing is when I turn the key on the mirror green light flickers for a sec then goes on and then brightens. I'm wondering if the camera not being hooked up causes it to do funny things. Either way when the camera comes in well see if it goes away.
Dohcv6 is offline
post #30 of 32 (permalink) Old 05-27-2017, 08:12 PM
Quoted: 2 Post(s)
Just checked and I'm not getting 12volts when switching into reverse with that red wire....humm
Dohcv6 is offline
