Serviceable front struts - Toyota RAV4 Forums
post #1 of 8 (permalink) Old 03-27-2019, 12:23 AM Thread Starter
Quoted: 0 Post(s)
Hey people first post here!
So I got a 1998 rav4 and I have taken it off road a couple times. Performed really well, anyways..I want to lift it. So i purchased a lift kit and unfortunately the lift kit came with the inserts for the front shocks. I currently have the sealed types. I have looked up down left right and centre to find serviceable struts for my rav4 but sadly nothing turned up. A bit upset about it. I posted in a couple rav4 Facebook groups and I got sent to these auto parts online stores. Looked around myself and then decided to email their support centre and they said that they do not have those types of front shocks. So I'm just wondering as it would be a bigger community here if anyone can please find a part number or send me a link for the serviceable front struts so that I can replace the inserts and finally install my lift kit. Would really really appreciate it. I am located in Australia and would prefer to get them from AU but if I can't find any then I won't have a problem paying shipping.
Appreciate any help
Anur1998 is offline
post #2 of 8 (permalink) Old 03-27-2019, 09:16 AM
Country: Roundabout's Flag is: United States
Roundabout's Avatar
Quoted: 94 Post(s)
Can you return the kit and order the correct kit for your Rav4?
I have heard that the early Rav4s had the serviceable struts but quickly changed over to the sealed struts. By the 99 manual they only show the sealed ones.
You are lucky to be in Australia were you have access to a wider range of Toyota parts for the Rav4.
I ordered my lift kit from Australia, Old Man Emu is the brand I bought.
99 Rav4 in Quicksilver
AWD & LSD with Moon Roof. Power Everything, except the manual Leather Seats and Transmission.
Selectable DRL, Inactive ABS, In-dash CB with Wilson roof-mount antenna, Clearance 10'8".
2.0l 5-speed.
86 Ford Truck
420ci 8-speed.
Roundabout is offline
post #3 of 8 (permalink) Old 03-27-2019, 09:37 AM Thread Starter
Quoted: 0 Post(s)
Yeah i was told that the earlier models had serviceable struts but im not sure how to determine whether they are or they are not. And not sure if they will fit on my 98 model. That's why I was a bit skeptical about buying them second hand from the junkyard. Do you happen to still have that link for the old man emu lift kit from Australia? I can't find any from Australia. The only one I found is from the USA and shipping is so expensive as they have a bit of weight. Or at least the part number for the front shocks?
Anur1998 is offline
post #4 of 8 (permalink) Old 03-27-2019, 01:02 PM
eodgator's Avatar
Quoted: 231 Post(s)
Anur1998, I was looking at the OME site (ARB Old Man Emu 4X4 SuspensionARB Old Man Emu 4X4 Suspension) and they have merged with ARB. When I looked at the selector, they no longer listed the RAV4 but it says to check with your local ARB parts store.
I did find some ebay.au listings, see https://www.ebay.com.au/b/Shocks-Str.../bn_7019824143
And this from another online parts supplier, see https://www.onlineautoparts.com.au/Q...manuId=&catId=
eodgator is offline
post #5 of 8 (permalink) Old 03-28-2019, 01:02 AM
eodgator's Avatar
Quoted: 231 Post(s)
I looked up the OME struts at https://www.rocky-road.com/ome-rav4-lift-kit.html and the part number is for the KYB334252 Excel-G Gas Strut.
eodgator is offline
post #6 of 8 (permalink) Old 03-28-2019, 04:41 AM
Country: room217's Flag is: New Zealand
Quoted: 18 Post(s)
My rav has got serviceable struts. It is a 1994.
I think they maybe sold you the wrong kit.
You said your are not keen getting from a junk yard? That's what I would do... if they are not too expensive.
To tell if the struts are serviceable or not you must look for a big nut where the strut finish and the shock shaft start. It is a pretty big nut, I had to use a huge pipe wrench + vise to take that off.
My spacers I got from Russia. But I am now a bit concern as I found out spring/strut spacers might not be legal in NZ. If I have to change my suspension I will get these raised springs. Shipping from here to Australia should not be too bad.
https://www.adenstyres.co.nz/product...nt=17334028870
1994 Rav4 J - 5 speed manual - 2 doors - AWD- Right hand drive Japanese import
room217 is offline
post #7 of 8 (permalink) Old 03-31-2019, 08:50 AM Thread Starter
Quoted: 0 Post(s)
Yeah I might have to grab something from the junkyard. Just wondering if the older shocks from a 97 or 96 will fit my 98? When opening it up do I have to worry about anything leaking or anything under compression? And the nut that I'm supposed to look for it on the top of the shock housing? If doesn't have that nut then that's not the one correct? Just want to double check because I don't really want to be spending money on stuff that won't fit
Anur1998 is offline
post #8 of 8 (permalink) Old 04-01-2019, 03:42 AM
Quoted: 18 Post(s)
Well, I can't tell for sure if will fit or not but I guess it will. As I said, I've got a 94 rav and I always buy my parts from Rockauto, and as far as I know in States the first rav was in 96 I think, and all parts fitted well so far.
Here you go, that's what you are looking for (pic in my suspension album). You can check before you buy, so you wont get nothing wrong.
On mine there was no pressure and yes, there was some oil inside
room217 is offline
front struts replacements salman1922 4.3 Mechanical 21 04-08-2019 06:04 PM
Is an alignment needed when replacing front struts? Carnivore 4.3 Mechanical 12 10-20-2018 06:53 PM
Which front struts to use with Bilstein shocks? Soliman23 4.1 Accessories 11 08-19-2018 01:07 PM
2006 Base Model rav4 front struts DearVienna 4.3 Mechanical 7 02-06-2018 06:30 PM
Front struts cost EarlMantis 4.3 Mechanical 20 05-03-2016 09:14 PM
