post #1 of 8 (permalink) Old 04-01-2019, 04:42 AM Thread Starter
Country: room217's Flag is: New Zealand
Quoted: 18 Post(s)
1994 Skid Plate
Hello all.
This is the last little project I had in mind and it is now finished. A skid plate.
I used a 3mm thick aluminium sheet (I dont know what grade and any other specification) and I bolted on the holes for the original plastic protection cover, except for one hole that I had to drill.
First I did a cardboard template to measure the size and also where to drill the holes on the plate. I also used a piece of rubber (heat pump bushing) just to keep the plate from touching the crossmember.
Then I cut the sheet to size using a grinder, and the fun part was to bend it. I cut a shallow fracture line where I wanted to bend, then I screwed down the sheet on the floor of my work van (think as a bench) to stop from moving up, then I start to bend it. It was really hard, I had to literally jump up and down on the edge of the sheet to make it bend. Was funny...
The other sides were easier to bend, just using a little wrench and a rubber hammer.
I bolted everything up using m6 bolts (I think) on six spots, so I think will be strong enough. The crossmember on the left was the only point I had to drill as there was nowhere else I could bolt into.
I will post a drawing with measuraments and take a better pic of the plate on the car.
1994 Rav4 J - 5 speed manual - 2 doors - AWD- Right hand drive Japanese import
room217 is offline
The Following 3 Users Say Thank You to room217 For This Useful Post:
eodgator (05-16-2019), Mick Hatzo (04-01-2019), SlimJim16v (05-16-2019)
post #2 of 8 (permalink) Old 04-01-2019, 02:41 PM
Country: PDX_RAV's Flag is: United States
PDX_RAV's Avatar
Quoted: 5 Post(s)
Love this. I've wanted to do this for awhile, glad to see someone else making it happen! Looking forward to final install pics.
PDX_RAV is offline
post #3 of 8 (permalink) Old 04-05-2019, 11:48 PM Thread Starter
Quoted: 18 Post(s)
Unfortunately I can't put on a hoist and my pics from the car on the ground never come out great.
Anyway, I've got three more pics... Not too shabby, I liked the result.
room217 is offline
The Following 2 Users Say Thank You to room217 For This Useful Post:
eodgator (05-16-2019), SlimJim16v (05-16-2019)
post #4 of 8 (permalink) Old 04-06-2019, 03:04 PM
Country: Commando's Flag is: Canada
Commando's Avatar
Quoted: 60 Post(s)
Good job!
2001 with 2.4 swap + RAV4.1 transmission (4.93 final drive ratio), RAV4.1 locking center differential, Lexus RX300 limited slip rear diff , Celica GT4 stage 1 SPEC clutch kit, 3" lift kit, Old Man Emu coil-springs, sway-bars delete and BFG MT KM2 235/70/16.
Commando is offline
post #5 of 8 (permalink) Old 05-16-2019, 01:19 AM
Country: zgarfield's Flag is: United States
Quoted: 0 Post(s)
Awesome. Want to build one for my 2000. Can't wait for measurements
zgarfield is offline
post #6 of 8 (permalink) Old Yesterday, 06:16 AM Thread Starter
Quoted: 18 Post(s)
I forgot all about it. I will post this weekend.
room217 is offline
post #7 of 8 (permalink) Old Today, 09:55 PM Thread Starter
Quoted: 18 Post(s)
Here it is. Measuraments added on my album.
I recomend you to do a cardboard template before. Just to double check the measuraments and also will make your life easier to drill the holes on the right places.
I used m6 bolts and drilled pretty generous holes (like 10 or 12mm) on the plate, this way you wont mess around too much trying to match the holes perfectly right. Will keep you zen... lol
Then I used a very big washer to cover the bolt head. Especially the two frontal ones that will go in a angle, they also need to be a bit longer than the others (like 40 or 50mm).
Have fun.
room217 is offline
post #8 of 8 (permalink) Old Today, 09:59 PM Thread Starter
Quoted: 18 Post(s)
** on the photo I meant "only hole you will have to drill on the car"
It will be close to the suspension arm bushing. And on this fixing point you will also need a nut.
room217 is offline
The mystery of the bent front license plate Flyover 4.3 Exterior 18 03-21-2019 11:40 PM
Road Hazard damage at skid plate caused CEL, TRAC, 4WD lights on cbird02 4.3 General 2 10-01-2017 09:31 PM
Loose skid plate SirTampers 4.3 Exterior 4 06-29-2016 03:05 AM
2004 Rattle-Loose heat shield or skid plate? Photopaul65 4.2 Faults & Fixes 4 02-06-2016 08:08 AM
Skid Plate...THEN lift kit! allwheelfun 4.2 General 0 11-09-2015 09:32 PM
