Transmission for 3sGTE swap - Toyota RAV4 Forums
post #1 of 9 (permalink) Old 04-01-2019, 10:42 AM Thread Starter
Country: jcubillo's Flag is: Costa Rica
jcubillo's Avatar
Quoted: 4 Post(s)
Hello all!!
After MANY years of having my gen4 3sgte engine laying around... I'll finally start the project of swapping it into my rav4. Wooof
Engine will be taken to a shop to prepare it and fix any details it may have and then it will be swapped into the car.
One thing though... right now the plan is to install it using the standard awd rav4 transmission... however... I know there are *better* options but I don't know what they are...
Anyone has any idea on which car had a better transmission to use with this engine? Either stronger or with better gear ratios or easier to use? My idea is to use this car as a regular street rav4 but with added power.. thats it... I don't want to make a monster out of it or race it or whatever...
Is it maybe worthwile spending some time looking for a celica transmission or a lexus 3sge one or something like that?
Thanks!
jcubillo is offline
post #2 of 9 (permalink) Old 04-01-2019, 02:36 PM
Country: PDX_RAV's Flag is: United States
PDX_RAV's Avatar
Quoted: 4 Post(s)
The main thing is that you need to upgrade the clutch as the OEM Rav can't handle the additional power for too long before failing. A Celica awd (185, 205) or Caldina trans might give you better ratio's for application of the power though. Interested to hear other inputs as well
PDX_RAV is offline
post #3 of 9 (permalink) Old 04-01-2019, 04:37 PM Thread Starter
jcubillo's Avatar
Quoted: 4 Post(s)
That's exactly what I waas thinking... I do know Toyota made the Rav4 gearbox a little "lowerer" in ratios to give it's trucklet some more toque/power and not so much speed.
However with the new engine it does make sense to have a gearbox with longer gear ratios that will have better use in regular street usage. Even now my 1st gear only last less than 1second before having to change gear... I guess with a 3sgte engine you probably have to start the car in 2nd gear with a stock gearbox...
jcubillo is offline
post #4 of 9 (permalink) Old 04-02-2019, 12:46 PM
eodgator's Avatar
Quoted: 223 Post(s)
Is your RAV4 AWD? If it is you also need to consider upgrading the rear differential assembly.
eodgator is online now
post #5 of 9 (permalink) Old 04-02-2019, 01:39 PM
PDX_RAV's Avatar
Quoted: 4 Post(s)
Originally Posted by jcubillo View Post
\Even now my 1st gear only last less than 1second before having to change gear... I guess with a 3sgte engine you probably have to start the car in 2nd gear with a stock gearbox...
I've wondered about driveability on the stock trans too, 1st gear must be pointless with a turbo unless you utilized it for offroad? Slightly off topic but I wish there was a way to make the vacuum actuated center diff locker work on the 3sgte swap.
PDX_RAV is offline
post #6 of 9 (permalink) Old 04-02-2019, 08:26 PM
Country: Commando's Flag is: Canada
Commando's Avatar
Quoted: 60 Post(s)
The rear differential don't need to be upgraded. It's the same internals/gears than a GT4/Alltrac Celica. But installing new diff mount bushings would be a good idea!
2001 with 2.4 swap + RAV4.1 transmission (4.93 final drive ratio), RAV4.1 locking center differential, Lexus RX300 limited slip rear diff , Celica GT4 stage 1 Exedy clutch kit, 3" lift kit, Old Man Emu coil-springs, sway-bars delete and BFG MT KM2 235/70/16.
Commando is offline
post #7 of 9 (permalink) Old 04-03-2019, 02:32 AM
eodgator's Avatar
Quoted: 223 Post(s)
The GT4s all have torsion differentials which were a very rare option on the RAV4.1. The standard rear differential may not take the torque.
post #8 of 9 (permalink) Old 04-03-2019, 05:57 PM
Commando's Avatar
Quoted: 60 Post(s)
From 1986 to 1993 (ST165 and ST185), there was no rear LSD. The torsen ONLY came in the rare RC Carlos Sainz special edition (1991-1992). From 1994 (ST205), then most had the torsen rear differential.
Those without LSD share the same gears and internals than RAV4.1 and RAV4.2.
The RAV4 Torsen (type 2) is different because GT4 had a type 1 Torsen. The type 2 is a little less efficient (more progressive torque transfer), BUT the type 1 is much weaker by it's design.
Commando is offline
post #9 of 9 (permalink) Old 04-05-2019, 11:57 PM
Country: room217's Flag is: New Zealand
Quoted: 18 Post(s)
Very nice, keep us up to date of your project.
1994 Rav4 J - 5 speed manual - 2 doors - AWD- Right hand drive Japanese import
room217 is offline
'01 Rav4 AT Transmission Success Story, P0770 Fix demoder 4.2 Faults & Fixes 2 03-11-2019 03:40 PM
Automatic transmission weakness and fluids Jeff Godon 4.3 Mechanical 99 02-28-2019 07:03 PM
2011 V6 4wd transmission troubles VitaminZ 4.3 Mechanical 12 10-21-2018 01:11 PM
Price Guide for ST215 3S-GTE Engine Swap AKA "The Rav4 GT-T" Rav4hunting 4.1 D.I.Y. and Modifications 0 04-26-2018 02:33 AM
