Smart Keys: Replacement Info & How-To - Page 10 - Toyota RAV4 Forums
post #91 of 93 (permalink) Old 10-21-2017, 11:52 AM
Country: Jrmg's Flag is: United States
Quoted: 1 Post(s)
Worked with 2014 RAV4 EV
Wanted to report here that this worked perfectly!
I recently bought a 2014 RAV4 EV, and it came with only one key.
I bought a used remote on ebay, (same FCC ID, reportedly from a Highlander), and a cheap VCI cable. After performing the reset procedure, it and the existing remote both registered fine, and now we have two working keys.
I have a Mac, so I ran the software with a VirtualBox install of Windows XP. I also bought a key blank, and I’ll try to get a locksmith to cut a copy of the physical key part of the original remote - that’s a task for this weekend.
Total cost, about $115, plus whatever the physical key cutting costs.
[edit: I forgot: plus €25 for the SEED code]
The only glitch was that, the first time I tried, the used remote didn’t register - turned out the battery had been removed.
Thanks -Unknown- for a great summary!
Jrmg is offline
post #92 of 93 (permalink) Old 10-21-2017, 12:27 PM
Quoted: 215 Post(s)
I have a Mac, so I ran the software with a VirtualBox install of Windows XP. I also bought a key blank, and Iíll try to get a locksmith to cut a copy of the physical key part of the original remote - thatís a task for this weekend.
[edit: I forgot: plus Ä25 for the SEED code]
The only glitch was that, the first time I tried, the used remote didnít register - turned out the battery had been removed.
Did you original Smartkey have the
FCC ID: HYQ14FBA
281451-0020 G Board? Someone said the Lexus also uses that board. Also does the rear hatch button work ?
@2011rav4 is offline
post #93 of 93 (permalink) Old 09-03-2018, 10:49 AM
Country: Lovaduck's Flag is: United States
Lovaduck's Avatar
Quoted: 9 Post(s)
Somebody sent me a PM asking if I had any luck resolving this issue. It has been a while since I posted my comments but I only had this solved last month. I had purchased standalone (without an attached key) remotes with the same FCC ID (Hyq12bby) but meant for a Camry. I could not program those with Techstream. I said I was going to try with the door open-close process but I didn't just carried on using the door lock by hand.
Then I ordered a full replacement key with the remote, immobilizer chip and had it cut. Programmed the immobilizer chip with Techstream, no problem at all. Then I used the door open-close process to program the remote buttons. That worked. After this success I decided to try with the standalone remote openers I had, using the same manual process, but no luck. So I believe those were faulty.
In any case it pays to try using the manual programming. I used a video meant for the whole process of programming immobilizer with techstream and remote by hand. https://youtu.be/4F3Xu_GdbqU the part about the remote starts at 3:50 mins. I played the video in my phone while doing the process, that made it very easy not to be confused with the steps.
So good luck with it!
Originally Posted by Lovaduck View Post
Thanks again! I will give this a try. I was aware of this procedure, but since I have the Toyota TechStream software I have tried using the functions there. There are two modes, one allows you to check if a remote is adequate and another allows to program a new remote. Neither one works. The detection works just fine with the old remote so I believe this one was used properly. The car will produce a sound when you press a button on a remote which is of the appropriate band (regardless of it being programmed).
I will report back after trying this process, it may work where TS failed.
Lovaduck is offline
