TEKSMRT's 2009 V6 4WD Sport SAP build - Page 2 - Toyota RAV4 Forums
post #11 of 88 (permalink) Old 08-08-2017, 09:37 AM Thread Starter
Country: TEKSMRT's Flag is: United States
TEKSMRT's Avatar
Quoted: 81 Post(s)
Picked up some RAV4 Sport floor mats... some reason mine didn't have any.
2009 RAV4 Sport V6 4WD SAP
.. too many mods to list ...Custom cold-air intake with heat wrap---Cat-back custom dual Magnaflow exhaust with staggered quad tips---R9KTuned ECU... list goes on and on..
TEKSMRT is offline
post #12 of 88 (permalink) Old 08-08-2017, 09:42 AM
Quoted: 1097 Post(s)
You do know that tinting the tail lights is illegal in TX right?
2008 Base V-6 (Hers)
2008 Limited V-6 (His)
RTexasF is offline
post #13 of 88 (permalink) Old 08-08-2017, 09:45 AM Thread Starter
TEKSMRT's Avatar
Quoted: 81 Post(s)
Didn't actually - but luckily the police have never bothered me with either of my vehicles - both have tinted tails.
TEKSMRT is offline
post #14 of 88 (permalink) Old 08-08-2017, 10:53 PM Thread Starter
TEKSMRT's Avatar
Quoted: 81 Post(s)
Started on the intake - found a cheap eBay short ram intake for the V6 Camry.
Kept throwing CEL - MAF voltage out of range. But it drove fine - so cleared codes... kept driving.
Drove around for awhile before I figured out that the underhood temps were skyrocketing. So I spent some time this weekend fixing my eBay SRI and making it a functional CAI. Took advantage of those who have done before and Myxalplyx's CAI parts list.
1. Started off with the following parts:
*eBay SRI ($57.99)
*3"-3.5" 45 4ply silicon transition ($8.44)
*12" of 3.5 aluminum tubing ($15.81)
*3.5" to 4" 4ply silicon straight transition ($9.08)
*4" 180 aluminum tubing (90 is all that is necessary)($30.67)
*4" 4ply silicon coupler ($7.09)
*4" to 6" velocity stack ($14.99)
*K&N RU-3100 6" cotton cone filter ($48.99)
*(3) 1/2" hose clamps from HD for 3"-4" pipe ($4.35)
*(3) 1/2" hose clamps from HD for 3"-5" pipe ($5.55)
*(2) rolls of reflective intake insulation wrap ($19.99)
2. Removed the bumper
3. Took out the OEM intake snorkel after removing the (3) 10mm bolts holding it in.
These little guys in the intake resonator - gross!!
4. Cut a 2" 4 ply silicon coupler lengthwise, trimmed the edges and epoxied it into the eBay SRI to reduce MAF housing size.
5. Started fitting the intake pieces all together.
6. Found that the 12in 3.5" tubing was about 1" too long and trimmed it down using a chop saw and a deburring tool to clean the piping edges.
7. Then realized that I didn't need the full 180 bend 4" tubing and chopped it down to about an 80 bend.
8. This is what I ended up using.
9. After all mocked up, I used standard hose clamps from HD and secured all the transitions.
10. Then to help with the engine temps effecting intake temps, I wrapped the intake in reflective intake insulation.
Even wrapped the MAF sensor...
For $226, its definitely not pretty, but its functional! Haven't tested it out in high heat temps, but I'm positive I won't see the 177F intake temps I WAS seeing with the eBay SRI.
Next, I plan on doing the coolant bypass as I won't be needing that in Texas. I did the same on my old Prius and it made a notable difference. Even when I lived in Canada, I never saw any issues when the temps dropped below freezing and having the bypass.
TEKSMRT is offline
The Following User Says Thank You to TEKSMRT For This Useful Post:
Myxalplyx (08-19-2017)
post #15 of 88 (permalink) Old 08-08-2017, 11:10 PM Thread Starter
TEKSMRT's Avatar
Quoted: 81 Post(s)
Throttle Coolant Bypass completed - took about 5min
TEKSMRT is offline
Myxalplyx (09-02-2017)
post #16 of 88 (permalink) Old 08-08-2017, 11:19 PM Thread Starter
TEKSMRT's Avatar
Quoted: 81 Post(s)
Worked a bit more on the stereo. Ran zip-tied wires to the back.
Started in on the dual 10" Pioneer shallow sub box and dual Polk Audio amps.
Still need to figure out how to keep the amps cool and covered. Looking for a push-pull fan setup.
TEKSMRT is offline
post #17 of 88 (permalink) Old 08-09-2017, 12:09 AM Thread Starter
TEKSMRT's Avatar
Quoted: 81 Post(s)
Did this little rear wipe mod on my Prius - worked well on the Rav4. Shave down the little tab on the plastic wiper cap and it allows you to pull the wiper away from the window. Makes it easier to clean.
TEKSMRT is offline
post #18 of 88 (permalink) Old 08-09-2017, 10:52 AM
pico's Avatar
Quoted: 583 Post(s)
I really appreciate your comprehensive documentation and excellent photos. Let us know how the intake filter works. I have only modest success with them on my sports car. (I use one over each of the four carbs.)
2011 Limited, V6, Blizzard Pearl
SE Minnesota
pico is offline
post #19 of 88 (permalink) Old 08-11-2017, 10:48 PM
Quoted: 2 Post(s)
Sorry about your two previous 'yotas . Thank you for filling us in on your build progress! Really like the mods so far. How does that stereo sound compared to stock?? My girlfriend is looking to purchase a RAV4 so I'm going to show her this thread to show what potential mods she can plan!
satchmo88 is offline
post #20 of 88 (permalink) Old 08-18-2017, 05:21 PM
Country: ThurzNite's Flag is: United States
Quoted: 69 Post(s)
Tek, sent you PM. Nice build!
ThurzNite is offline
