Doorlock key problem 2009 - Toyota RAV4 Forums
post #1 of 6 (permalink) Old 04-22-2019, 10:12 PM Thread Starter
Country: fumigator's Flag is: United States
Quoted: 1 Post(s)
My daughters 2009 driver door lock will not lock mechanical by the key. Unlock works fine and lock/unlock work via the the remote but the lock will not work. Was not always this way. I tried some graphite powder with no change. Same for both original keys. Any thoughts? Thanks in advance.
Sent from my SAMSUNG-SM-G930A using Tapatalk
fumigator is offline
post #2 of 6 (permalink) Old 04-23-2019, 08:56 AM
Quoted: 382 Post(s)
Sure sounds like a problem with the lock cylinder. If it were me, I wouldn't worry about it as I've never used the key on the door. Even if the battery dies on the remote, the key will still unlock it.
ravenuer is offline
The Following User Says Thank You to ravenuer For This Useful Post:
fumigator (04-23-2019)
post #3 of 6 (permalink) Old 04-23-2019, 10:39 AM
Quoted: 466 Post(s)
It appears the door lock arm connected to the door lock cylinder has disconnected. If you are handy take the door cover off and investigate the door arm connection.
2009 RAV4 Sport V6 4WD
2005 RAV4 Base 4WD -sold
DL175 is offline
post #4 of 6 (permalink) Old 04-23-2019, 12:33 PM Thread Starter
Quoted: 1 Post(s)
Thanks for the responses. It may be more related to just the master key and maybe tip wear.. i thought she told me both keys but appears now just the original master key which has all the use. Just seems odd if key wear is the issue that it would be limited to allow unlock but not lock on door and still works fine in ignition.
post #5 of 6 (permalink) Old 04-23-2019, 01:34 PM
Quoted: 466 Post(s)
If you tried 2 different keys and both don't work then it is not the key. The door arm could be loose. The door key cylinder is able to open but the door arm is probably required to lock it.
DL175 is offline
The Following User Says Thank You to DL175 For This Useful Post:
post #6 of 6 (permalink) Old 04-23-2019, 01:44 PM Thread Starter
Quoted: 1 Post(s)
I was wrong. Only one of two keys and the key with most wear. Daughter is 2 hours away so information i get can be suspect at times.
Hawk Brake Pads HPS - which part number? MyEeek 4.3 General 5 02-19-2019 10:20 PM
Buying a 2009 4-cyl and looking for problem areas wkilby 4.3 General 21 02-08-2019 10:59 AM
Adding an extra key using Techstream! JuneBug 4.3 General 231 12-27-2018 08:27 AM
2009 Toyota Rav4 Key Fob Computer issue- no start, no communication Texasrav09 4.3 General 11 09-16-2016 02:59 PM
Ignition barrel problem mudinuri 4.1 Faults & Fixes 5 11-15-2015 04:11 AM
