Inside rail near jack point bent - Toyota RAV4 Forums
post #1 of 7 (permalink) Old Yesterday, 10:23 PM Thread Starter
Country: dan_rav4's Flag is: United States
Quoted: 1 Post(s)
Last fall, I noticed my mechanic somehow managed to ruin my driver side front jack point, to the point the pinch weld is bulging so much the OEM jack doesn't fit anymore. Today, I tried to lift the vehicle using a pinch weld adapter block with slightly wider grooves, and the inside rail just disappeared into a pile of dust.
Is this just a cosmetic issue, or are there structural concerns? What would be the safe way to lift that section? They do use road salt here, and while the other jack points/rails seem to be fine, I'm concerned I'll run into the same issue.
Suggestions?
dan_rav4 is offline
post #2 of 7 (permalink) Old Yesterday, 11:29 PM
Country: rdublin's Flag is: United States
Quoted: 2 Post(s)
The FSM specifies using rubber adapter blocks when lifting on those points, possibly to prevent damaging the corrosion protection. I would not expect that you can use this a lift/jack stand point any longer, so from that perspective it is a structural issue. I am not even sure where you would take it for evaluation. The dealer may be able to assess, but a collision repair facility might be a better bet. Regardless, you need to do something to arrest that rust or it will keep eating its way into your truck.
Rod
rdublin is offline
post #3 of 7 (permalink) Old Today, 08:13 AM
Quoted: 249 Post(s)
That damage is not anything dangerous. It's where the rocker panel connects to the under body. I would get it fixed for sure tho. As far as lifting goes you can use the frame. Do you park it on grass often? That is some pretty bad rust for such a young car.
Rav4system3 is offline
post #4 of 7 (permalink) Old Today, 10:19 AM
arf
Quoted: 58 Post(s)
What year is this?
arf is offline
post #5 of 7 (permalink) Old Today, 08:46 PM Thread Starter
Quoted: 1 Post(s)
Always parked in a closed (but vented/unfinished) garage, but I do live in an area which is known to use more salt than Burger King.
Originally Posted by arf View Post
What year is this?
2007
dan_rav4 is offline
post #6 of 7 (permalink) Old Today, 09:06 PM
Quoted: 1191 Post(s)
2007
Interesting that you have EVERYTHING but your year, trim and drivetrain listed in your signature. Thread moved to 4.3 Exterior
Where you park apparently isn't the issue, where you drive is. As mentioned the jack point isn't a concern, the extensive rust certainly is. I'd suggest you have the underneath thoroughly inspected for rusted frame parts and their attachments.
While checking my '06's rear alignment I found the rear subframe almost rotted thru near the front left end. If I couldn't have bought a used one and replaced it myself the car would have been a parts car. All other areas were okay.
1968 Volvo 1800S
Dr. Dyno is online now
post #7 of 7 (permalink) Old Today, 09:30 PM
Quoted: 448 Post(s)
Well the pinch rail is rusted out so using that is out of the question and any pressure will bend it further. You can use the frame which runs the length of the pinch rail. Just look under the car and you will see a frame rail that is about 2 inches wide further in of the pinch rail.
2009 RAV4 Sport V6 4WD
2005 RAV4 Base 4WD -sold
DL175 is offline
Floor Jack Question / Rear Jack Point Access Issue kjarrett 4.3 Mechanical 23 03-28-2019 04:26 PM
Floor Jack Lift Point DL175 4.3 General 0 10-29-2018 12:40 PM
OEM Running Board and "jack block" to be added to the scissor jack prechierav 4.4 Exterior 16 07-10-2018 12:36 PM
Tire Shop missed jack point and bent frame Xhado 4.3 Mechanical 6 04-24-2018 08:54 PM
Relocating aux jack to inside of console storage box Rav450 4.3 Interior 6 07-10-2016 02:48 PM
