So, i changed all the fluid on the new (old) RAV4. Diff, transfer/transmission, engine, brakes, servo, and coolingsystem.
I have read everywhere on this site, how important it is to use original oil filters cause of some valve inside the filter...
So I bought the filter at Toyota service center, and took some Pictures side by side of the OEM vs some aftermarked that was installed on the vehicle.
Here you can see that they (almost) have the same partnumber, but looks very different:
- Different size holes
- Some kind of "neck" in the middle
Here on the next Picture:
- Bigger holes inside aftermarket filter
- Looks like it has some sort of pattern inside aswell
In this Picture you can se the valve Down the bottom (Toyota filter)...
Here is another Picture of the valve:
And last, the aftermarket with just a flat bottom.. No valve..
The aftermarket oil filter was in the car when I bought it... Was driving fine... I really don't think I will notice any change now when I changed it to the OEM filter with valve.... But I'll bet the engine will thank me for it
