Anyone installed a Fumoto or similar oil drain valve yet? Wondering what size the 19' takes.
Thanks, my 4th gen 4Runner uses the same one, is M12-1.25 standard on Toyotas?Same as before, 18-19 Camry have the same A25A engine as the 19-20 Rav4.
Fumoto F-103 Engine Oil Drain Valve to fit 1988-2020 Toyota Camry at MyCarWorx.com
Quick and Easy Engine Oil Drain Valves by Fumoto to fit Toyota Camry 1988-2020.www.mycarworx.com
Yeah, might not be universal, but fortunately, my 4th gen 4Runner has the 4.7L V8 and with confirmation from TonyYOW, it does actually use the same size since I have a spare one somewhere in the garage!My general search on Toyota's site, does not look like it's a one part across all Toyota's. Generally it looks like the 2.5-3.5 liter are these plugs, the 2.4 from the 1980's is different, the bigger 4.7 liter have another plug and the smaller engines have another. Then engines not made by Toyota (made by Subaru or BMW) have another plug.
I am probably going with a ValvoMax on my next oil change. Advantage ValvoMax is the oil will come out in a tube (right into a container), so it will be a very clean oil change (in theory right). Of course with the Fumoto, there is no extra part to lose.
For the F103SX model:I finally did my first oil change at 12,000 km. That's when I finally installed the F103SX that was waiting for almost a year on a shelf.
Installation was easy and I'm so happy I chose F103SX because it allows you to choose any position for the valve. I torqued it to 15 ft-lbs, as per the torque chart for Fumoto valves.
me too, have used it in my other 3 cars, and have been loving it!!The clearance is all good, there is lots of space for it. No leaks.
I used fumoto valve for my other 2 cars, and they never leaked. I truly love them.
Hey, to install F103SX, do we need to put on the OEM washer as well, or without since there is already a seal on the valve?? And what's the torque, is it 15 lb??The clearance is all good, there is lots of space for it. No leaks.
Absolutely not, you don't put OEM washer. The valve has its own seal.Hey, to install F103SX, do we need to put on the OEM washer as well, or without since there is already a seal on the valve?? And what's the torque, is it 15 lb??
Highly appreciate any help, will be doing oil change tomorrow ;-)
Thanks for all your help. I got it installed yesterday and everything went pretty straight forward. However, when I torqued it down, it actually moved the valve out of my set place, which didn't bother me much coz I would hook up a tube to the nipple to avoid any splashing when i use it. Overall, it looks good and is a good buy!! definitely like this new SX model for sure!!Absolutely not, you don't put OEM washer. The valve has its own seal.
Did you take any pictures that you can share?Thanks for all your help. I got it installed yesterday and everything went pretty straight forward. However, when I torqued it down, it actually moved the valve out of my set place, which didn't bother me much coz I would hook up a tube to the nipple to avoid any splashing when i use it. Overall, it looks good and is a good buy!! definitely like this new SX model for sure!!
No picture, but it is really easy, almost plug and play, and it's perfect fit without any clearance issue. My tips would be that you might want to set your valve facing 1/4 off your desired direction, giving it room to move when you torque the nut down.Did you take any pictures that you can share?
