For those with the gas powered 2019 + AWD rav4, how offroad capable do you find it stock and also with A/T tires.
It should be able to go unpaved road or light off road. Check youtube for some examples. Due to the clearance and power, you may not want to do extensive off road driving.For those with the gas powered 2019 + AWD rav4, how offroad capable do you find it stock and also with A/T tires.
My question with this: why not just wheel a cheap used 4x4 and then keep the RAV4 for everything else? Something 2 or 3 grand that you won’t mind scraping and dinging up. To each their own but nonetheless cool to see the capabilityView attachment 162939
Actually managed to get a little stuck today! Fully stuffed the right rear and left front coming over a hill with a sharp bend, with the right front hanging in the air about 4". There wasn't quite enough umph in the braking system / traction control to drive forward on the two stuffed tires, but squeezing the traction boards under the two light tires was enough. My tires, while aired down to ~16 PSI for thtis, only have about 30-40% tread left which certainly didn't help.
The recently lift helped a lot today with no bottoming out, though I need to work out a way to increase my downtravel because I only have like 1.5" right now hah.
I usually don't wheel much anymore just for the sake of wheeling, but rather as part of day trips and such. Driving a couple hundred miles in a realtively quiet, dual-climate-controlled, almost-self-driving vehicle that still gets 25+ MPG on said trips is pretty pleasant. Driving a couple hundred miles in a loud $2000 Jalopy that may or may not reliably get me there and back without breaking down sounds a lot less exciting to me--and even less exciting for my wifeMy question with this: why not just wheel a cheap used 4x4 and then keep the RAV4 for everything else? Something 2 or 3 grand that you won’t mind scraping and dinging up. To each their own but nonetheless cool to see the capability
I’d just personally be hesitant about wheeling a new $35k crossover like that.
Understandable. I’ve gotten used to only having to drive an hour tops to go wheeling, at least for the past 8 years. Had an old 84 solid axle pickup that wasn’t pleasant during transport, but never left me down once on the trail.I usually don't wheel much anymore just for the sake of wheeling, but rather as part of day trips and such. Driving a couple hundred miles in a realtively quiet, dual-climate-controlled, almost-self-driving vehicle that still gets 25+ MPG on said trips is pretty pleasant. Driving a couple hundred miles in a loud $2000 Jalopy that may or may not reliably get me there and back without breaking down sounds a lot less exciting to me--and even less exciting for my wife.
Fortunately, I do have enough experience off-road to know how to flirt with the boundaries between stuck and unstuck without approaching the boundary between stuck and broken. I don't particularly care about the occasional light scratch or ding if I earn it while out having a good time.
FWIW, I also wheel our 45k TRD Pro 4Runner.
Yeah. I historically have just daily-driven more off-road-oriented vehicles. But, like I said, evolving priorities have led me to seek to do what I can with the Rav (which is fun in its own right--for example, dual solid axles with dual selectable lockers can almost get boring on all but the most extreme trails).Understandable. I’ve gotten used to only having to drive an hour tops to go wheeling, at least for the past 8 years. Had an old 84 solid axle pickup that wasn’t pleasant during transport, but never left me down once on the trail.
I am lifted ~2 inches up front, ~4" rear, have no anti-sway bar's, and am running 2" taller tires than stock (which are ATs), and have the ability to air them down for off-road use. That said, I'd put my XLEP up against, for example, any stock 4WD vehicle without locking axle(s) . The biggest remaining weakness is the lack of low range, which will cause the transmission fluid to get warm with a lot off slow-speed, high-load driving (like a long, steep climb, or a lot of 1mph steep obstacles). I monitor these Temps and haven't had issues, but am aware of the possibility.
**Yes, with the same mods, any 4Runner or whatever would be back ahead in off-road prowess. But, that is where I'll cite the balance of my 50% better fuel economy.
1) It started as a ReadyLift kit. I just googled it. I am not currently using any of the rear pieces since that is all custom now, but still have the front 2" spacer. I think functionally speaking pretty much all the lifts provide about the same overall benefit.Hey so, I'm considering buying the prime new here shortly.. a few questions for you kindly:
1. Where did you get your lift?
2. Why did you take out anti-sway bars?
3. which exact tires are you running, and why?
4. how are you monitoring the temps? (OBD II connector?)
5. Theres no way to add a cooler?
6. any way to add air suspension? (to ride low during highways, then go really high for off roading.)
7. Do you think this can all be done on the RAV4 Prime (I know this isn't the Prime forum, just asking)
Thanks!
