I did a transmission drain and fill on my 2015 LE and took a couple pics.
Mileage is just under 56,000 so it’s close to the severe service recommendation of 60,000 mi.
I decided to give it a shot after waiting 100k on my 4Runner and it looked like that was longer than optimal.
I decided to use Toyota ATF-WS and bought 2 cases of 6 qts ea.
Toyota Part numbers:
WS-ATF: 00289ATFWS
Drain plug gasket: 90430-12008
Fill plug gasket: 90430-18008
Torque specs:
Plastic oil filler tube = 7 in-lb
Drain plug torque = 29 ft-lb
Refill plug torque = 36 ft-lb
Hopefully you are able to find a dealer not too far away that charges significantly less than list if you use the Toyota Parts website here…
I reused both the drain plug and fill gaskets/washers since they’re just aluminum crush.
Tools used:
ScanGauge
Motive Power Fill fluid transfer pump.
Two 2-1/2 qt buckets from Home Depot
Ratchet/Breaker Bar
Socket extension
6mm Hex Socket
24mm or 15/16 socket
Small and regular size flat blade screwdrivers to remove plastic clips
WS-ATF: 00289ATFWS
Torque specs:
00289ATFWS - Genuine Toyota Automatic Transmission Fluid-WS. ATF – WS - Genuine Toyota Part
Genuine Toyota Part # 00289ATFWS (00289-ATFWS, 0888602305) - Genuine Toyota Automatic Transmission Fluid-WS. ATF – WS
parts.toyota.com
Tools used:
ScanGauge
Ratchet/Breaker Bar
Socket extension
6mm Hex Socket
