Today, April 22, 2022, I purchased a 2022 RAV4 Hybrid Limited. In the back, there was an unopened bag with "Toyota Cargo Net", PNI # 500885180000 on the cardboard top, and a label on the plastic bag portion that says "Description: Toyota RAV 4 Hideaway Net - DIO" and "Part No.: PT347-42190".
The bag unzips easily. That's where installation stops and the head scratching begins.
I want to mount the net so that the bottom is stretched between the two D-rings near where I'll be loading cargo and the top (open side) attaches to ..... nowhere because there is no place to attach the top of the net so that I can put groceries or whatever in VERTICALLY. Even worse, the closed end of the net won't stretch far enough to reach both D-rings.
The only way to "install" (and I use that term loosely) the net is:
The issue seems to be there are no D-ring attach points for the top of the net. I just purchased the vehicle, so I'm hoping I won't have to go out and buy some after-market attach point and figure out how to mount it myself to achieve the normal way (I'm pretty sure I speak for most people here) people would expect a cargo net to function.
I've reached out to the dealer to see if they have any ideas. YouTube has some wild, scary looking "solutions" that I'm not ready to use because none of them address both the problem of the bottom hooks not being able to stretch the full width of the cargo area and no attach points high up in the cargo area to attach the top/open end of the net too.
- attach the narrow/bottom side of the net to the D-rings near the rear seats because those 2 rings are closer to each other.
- attach the top/open side of the net FLAT on its side using the the two wider-spaced D-rings near the entrance to the cargo area.
