1 - 20 of 22 Posts
RossL
2012 Base 4 wheel drive 2.5
I have the brake caliper and rotors removed. The ball joint separated and the axle is out of the hub.
I pulled on the axle and the CV joint/boot came apart closest to the carrier bearing. I have the carrier bearing clip ring released (which was heavily rusted to the carrier bearing bracket). Bearing is rusted to the bracket. I removed the retaining bolt on the carrier bearing bracket, sprayed everything with PB Blaster.............. I even removed the three bolts holding the CB Bracket to the engine.
I pulled the axle apart and used a vise grip and 5lb jack hammer but I can't get this to move. I was hoping I could pull the entire assembly (Axle, Bearing and Carrier bearing bracket) out...................
I am now considering cutting the axle behind the bracket to removed the bracket. Then weld or attach "something" to what's left of the axle to use the jack hammer.
Any thoughts?
Example of vise grip and hammer
If you could post a picture to show the problem, it would help.
Reading this, I think you have you have part of the axle separated and stuck in the diff?
If so, on ours when I removed it, the casing that is still in the diff has a couple of small flanges on it, I used a long pry bar and tapped it out with a lump hammer - hope this is on the right lines
I will get some pictures tomorrow. Ran out of day light.
Yes the axle came apart at the CV joint that’s at the carrier bearing. From right to left the cup of the CV joint, the carrier bearing/ bracket, then the trans case.
Since I can’t separate the carrier bearing and bracket, I removed the bolts hold the bracket and was trying to pull out the entire assembly with no success
You will transmit the jackhammer shocks inside the differential. It's really a nightmare situation, due to rust.
The inner joint of the CV axle is supposed to came apart like that, that's not a problem. Maybe wait a bit more for the penetrating lubricant to do it's work. A CV axle separator and slide hammer are all that should be required.
Been there, fighting rust, and will never even look at a car with rust (to buy). I gave up on that car when the rust on a brake line busted a hole, leaving me without brakes, luckly on my driveway.
Here are the pictures of where I started today. The slide hammer would not budge the assembly.
I ended up cutting the axle off before the carrier bearing bracket. I found two dowel pins in the bracket that insert from the bracket into the engine block, they were preventing me from pulling the axle/carrier bearing out. Once I cut the axle (two carbide steel cutting blades) and 2 plus hours with the sawzall...............the axle slid right out. There was no "C" clip, the carrier bracket is what hold the axle in place. There is no provision for the "C" clip, replacement axle is the same.
I at first thought maybe I dropped the C clip and I was a little worried But after expecting both original and replacement axles, there was no channel machined in the splines for the C clip. All of the Youtube examples show the clip. Next issue removing the bearing from the carrier bracket
Axle back in noise is gone. Cutting axle was a pain with a sawzall, which was the only tool that could fit between the frame, engine and exhaust. The pins in the carrier bearing bracket really set me back. I wasted a lot of time trying to pull out the axle and carrier bearing bracket as a unit.
I have the Chilton manual but it did not show the pins that went from the carrier bracket into the engine block. Is there an on-line resource that shows more detail?
This thread is about my experience with the front left:
I wedged the flat end of a crowbar between the "cup" of the axle and the transmission and applied a twisting force on the hooked end.
I got the idea from a Youtube video I saw where someone did this with a bigger Toyota, a Highlander or Land Cruiser perhaps. Wasn't a Rav, but similar axle design and still worked for me.
RossL
Firstly, well done on getting the job done.
For references, if it helps you, I use a couple of sources.
For parts lists, I use a free site toyota.7zap.com. It gives a complete break down of every system and lists all parts down to clips, nuts and bolts for example.
I also have a 4 year subscription to Mitchelldiy for one of our other cars. Costs 40USD for the 4 years and I find that very useful too
Hope this helps
I've never heard of them (mitchell diy) either, how do they compare with alldata ? The last repair job I did, I used the toyota official one for a weekend use and downloaded stuff for what I was doing, but compared to a chevy set of service manuals I thought a bit lacking.
If you have access to the official Toyota site, that would be at least as good, if not better, than say Alldata or Mitchell. Some of the pros do use Alldata as their subscription would cover multiple makes. Mitchell DIY is like Alldata but they allow one vehicle access for either 1 or 4 years
Thanks for the tip on the carrier-bearing bracket dowel pins. My 2014 RAV w/ 100k mi was continuously pulling to the right after 5 return visits to get the steering aligned before finding out that the carrier bearing was dragging and causing the right front wheel to pull the car. I also confirmed that when the front was jacked up the bearing made an audible noise by just turning the wheels by hand and I could hear the faintest rotational noise when driving. I ordered the bearing from Toyota and went to install it before reading this post and kept sledgehammering the axle to get it to pop out and it wouldn't move at all because of the dowel pins. I then found a full aftermarket axel from Autozone for $100 that included the axle and new bearing so I returned the standalone bearing.
I was able to remove the pins by wedging a large flathead screwdriver between the engine case and the bracket. This wedged it just enough for them to fall out but it still wasn't easy to remove the axel after that. I then had to break the bearing in order to easily slide out the axel assembly. The bearing bracket has a threaded hole at the bottom which I used to drive a bolt through to crack the bearing casing. Then I had to break the bearing cage to get the balls to come out and the axel finally easily pulled out.
The car is finally driving perfectly straight and returned to a quiet ride!
Okay so if my car has no rust what is the process for replacing the passenger side front CV axle?
I was lucky in that mine just slid out. I was prepared to cut the axle too, but living in a non rust area, I did not have a problem. I even bought a used bearing carrier because I could not have more than 1 day of downtime and needed to be ready for the worst case scenario. Here is my post from a couple of years ago when I did my 2009 RAV4 base, 2.5. 2009 RAV4 base 2.5 passenger axle replacement
Reactions: Bigphil555
How hard is it to just pull the old axle boot off at the cup and take a new axle apart and just clean up the old one and transfer all the grease from the new one into it and put it back together with the new half? Is that a viable option, or is that carrier bearing or cup likely the cause of most of people's problems that require the replacement in the first place? P.S. I have had to replace the whole thing before, and I have to do it on another one and don't want to go through that nightmare again.
1 - 20 of 22 Posts
