I'm wondering if anyone is able to confirm if the fuel tank/sensor issue has been fixed in 2022 production model hybrids?
Ditto.I have a 2021 built in the last 6 months and don't have the fuel tank issue
t installed correctly? Of course. But it certainly hasn't been an often reported issue here.Nope, this issue is experienced by me in my 2022 RAV4 PRIME xse. The dealership beats around the bush and gives hollow irrational explanations.
Let me attempt again to explain.The new parts are used in all 2022 builds. Is it possible that some are no
Exactly what do you describe as your issue that would cause you to think "this issue" is one you are experiencing.
The advertisied fuel tank capacity is 14.5 gallons for 2022 RAV4 xse whereas I went to fuel in when empty sign popped up, and the tank could take only 10.5 gallons of gas. I did the above iteration 4 times. Each time it s the same outcome.
I am an owner of a '19, no connection to Toyota other than I have owned several. This from A5 in an official Toyota CSP 20TE04 to owners. I have posted elsewhere on this forum the diagram from the Society of Automotive engineers detailing how gas tanks are supposed to work, and read the NIST document that is in agreement.Interesting! Could you please validate if all 2022 RAV4 Xse tanks can take no more than 9.8 gallons of gas?
Also, are you an authorized Toyota rep?
Yes…As a former owner of a 2019 XSE that had the tank replaced, and a 2022 XSE I can say the 2022 tank behaves similar to the 2019 after the tank replacement. No complaints.I'm wondering if anyone is able to confirm if the fuel tank/sensor issue has been fixed in 2022 production model hybrids?
I bought a 2022 RAV 4 Hybrid, a few weeks ago and soon I realized that mine doesn't read correctly. The first time I had to drive long distances in severe weather, although the tank said 3/4 full, it took 9 gallons of gas....more than half the capacity (14.5 gals) of a full tank. not just a quarter tank as the reading said. Then the second time it said there was only 1/4 tank remaining, so I pumped again. The second time I could pump only 4 gallons and the tank was full. So NO, I don't think they have fixed anything. Mine came out of the factory very recently.I'm wondering if anyone is able to confirm if the fuel tank/sensor issue has been fixed in 2022 production model hybrids?
