Just purchased a 2023 Rav4 Hybrid Limited. The instrument cluster is so dim during daytime I can barely read anything in the display. Yes I have the adjustment set on max brightness. Is there any other way to increase the brightness of this display?
The instrument brightness knob has a detent just before max. Be sure you rotate the adjustment beyond that detent.Just purchased a 2023 Rav4 Hybrid Limited. The instrument cluster is so dim during daytime I can barely read anything in the display. Yes I have the adjustment set on max brightness. Is there any other way to increase the brightness of this display?
Already have it there. I think i will go back to dealership and have salesman show me another new rav4 and see if dash is as dim.The instrument brightness knob has a detent just before max. Be sure you rotate the adjustment beyond that detent.
I have it on auto now. But I did try turning headlights on. Didn't help. Will try parking light option when wife gets home with vehicle. ThanksTry to turn the light switch from off to either drl or the parking lights option. Give it a shot and report back
Parking lights or regular headlights should change it. Send a picture. I’m hard pressed to think it’s defective. I would think that something like that would be caught during pre sale inspection but who knows.I have it on auto now. But I did try turning headlights on. Didn't help. Will try parking light option when wife gets home with vehicle. Thanks
Was there any solution to your issue? We have exactly the same issue with a brand new 2024 model. If this is serious enough and no solution is found, there may be more options being on a level of recalls.Just purchased a 2023 Rav4 Hybrid Limited. The instrument cluster is so dim during daytime I can barely read anything in the display. Yes I have the adjustment set on max brightness. Is there any other way to increase the brightness of this display?
This does seem to be specific to clear sunny days around 1 pm or noon. When you have to wear sunglasses on top of the dim display there is certainly a potential for driving issues if not dangerous circumstances to occur.Parking lights or regular headlights should change it. Send a picture. I’m hard pressed to think it’s defective. I would think that something like that would be caught during pre sale inspection but who knows.
For all the new rav 4 dash videos that are on YouTube do they appear about the same or not even close to yours?
Just purchased a 2024 Rav4 Limited. The instrument cluster is so dim during daytime I can barely read anything in the display. Yes I have the adjustment set on max brightness. Is there any other way to increase the brightness of this display? Were you able to fix your same issue?We noticed the same problem with our new RAV4 today - speedometer, etc are very dim during the daytime. Almost a safety hazard. We had the brightness control all the way up and past the detent.
It may be the sunglasses if they have polarized lenses they can block the light from just certian directions. Most try to block glare from below eye level, like glare from a body of water.No solution in our case. The only thing that's really readable during Sunny days with sunglasses on is the large-ish digital speed display. My wife drives the RAV4 99% of the time now and I think she has just gotten used to the dim display.
The 4th generation had a problem with the instruments being hard to see. There were many complaints about it when I owned my 2013 on the Toyota "ask and owner" web site.I have same problem with 2014 RAV. Only had problem last 18 months. Is there a bulb there that might have worn out? It's a big problem and I won't get another RAV
